Thread: Roof - Extrusion Along path - Conceptual Mass - 3D curve
    2009-05
    22
    Default Roof - Extrusion Along path - Conceptual Mass - 3D curve
    Hello,I would like to creat this 3D roof geometry, but I don`t know which is the best way of doing it?
    The roof edge is curved in plan and in elevation.
    I would like to "extrude along path" the edge profile.
    what is the best way?
    2009-03
    Somerville, MA
    1,060
    Default Re: Roof - Extrusion Along path - Conceptual Mass - 3D curve
    You may not have to work so hard. This is what I would try:
    1. Create a mass with the geometry of the roof surface where the edge of the surface is the path you are indicating in your 3D sketch.
    2. Apply a roof by face on this mass of whatever thickness your roof is.
    3. You may be able to apply a Roof Fascia profile to the edges of your roof, or you could create an In-Place Component and create a sweep picking the edge of your roof as your path.
    Depending on the geometry of your roof and profile, you may get some glitches. I tried both fascia and an In-Place sweep with a similar (but different) geometry and both failed.
  1. Replies: 3
    Last Post: 2013-09-11, 12:29 AM
  2. conceptual mass (help me!)
    By esi_badghelegh in forum Revit - Conceptual Design Tools
    Last Post: 2011-12-30, 04:50 PM
  3. Mass floors in conceptual mass family environment?
    By twaldock in forum Revit Architecture - General
    Last Post: 2010-11-15, 11:44 PM
  4. Conceptual Mass Paneling
    By jamie.mann in forum Revit Architecture - General
    Last Post: 2009-07-08, 01:25 AM
  5. Roof Mass & Extrusion
    By bgauthier in forum Revit Architecture - General
    Last Post: 2007-05-24, 08:37 PM
