Thread: how are you indicating paint colors?
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Default how are you indicating paint colors?
    I am working on a school project that wants lots of cheerful paint accents to liven up their facility. In the past I would add NSEW finish columns to the finish schedule and indicate P-1, P-2 etc. We have many oddly shaped rooms and the NSEW approach doesn't work very well. My first thought is to add keynotes to elevations and mark the schedule "see elev ###", but some of the simpler rooms don't have elevations drawn. I don't want to create elevations just for paint keynotes.
    Any thoughts?
    2003-03
    Philadelphia, PA
    2,392
    Default Re: how are you indicating paint colors?
    This is likely not the "BIM" way, but we use a "dumb" annotation with leaders to call out accent finishes on walls in the finish plan. The annotation has a label to hold the designation for the accent treatment, which is entered manually. This is the same way we (and when I say we, I mean our interior designers) do it in CAD, hence, not the "BIM" way.
    2009-06
    St. Louis, Missouri
    162
    Quote Originally Posted by dkoch View Post
    I'll second that approach. Unless you're going to try and quantify the amount of each paint used, or creating a rendering of that room, there's no point in going through and splitting faces and painting the walls so that they tag accurately. We indicate in our room finish schedule the paint colors used on each wall (N/S/E/W). If more than one color is listed, a general note says something along the lines of "refer to elevation/plan for extents". In the elevations, we use detail lines (or model lines if it appears in a 3D view) to draw out where the accent paint(s) go(es).
    2015-10
    New York NY
    1,497
    Quote Originally Posted by rosskirby View Post
    That's the way I did it long before Revit came along. I was just wondering if anybody had discovered a new improved method using Revit.
  1. Settings for Indicating Thousands in Dimensions
    Last Post: 2012-07-18, 03:40 AM
  2. Variable creation indicating how many existing layouts within our drawing
    Last Post: 2011-11-16, 09:23 PM
  3. Indicating Seismic Joints on Plans
    By RobertB in forum Revit Architecture - General
    Last Post: 2010-08-31, 04:43 PM
  4. Replies: 3
    Last Post: 2010-06-20, 11:58 AM
