Thread: Mtext command is not functioning properly.
    2013-04
    Default Mtext command is not functioning properly.
    If a new mtext window is opened, and I type a note, it appears as (chinese?) text. If I try to edit existing mtext, no characters appear in the window when typing. The text command works fine on same pc. Language on this license is using Western (English). Can this be fixed?
    TN/KY Area
    1,640
    Default Re: Mtext command is not functioning properly.
    Is this a new install or did it work OK before? Do you have all the Service Packs installed?
    2013-04
    This was working fine for 6 months after install. All Service Packs have been installed. It was working fine Wed. afternoon, then on Thursday morning it was not working. I checked to see if any Windows updates Wednesday evening, and there were none.
    2013-04
    This mtext issue has been resolved. We don't know how this was fixed, but relieved it was. What I did was type in the mtext window using center justification and entered in over 200+ characters when suddenly it was working fine. Whew!
  1. 2012: Global Attribute Edit Command not functioning in AutoCAD 2012
    By alex.kolb in forum AutoCAD General
    Last Post: 2018-11-08, 09:47 PM
  2. 2014: SCALELISTEDIT command is not functioning
    By prowley459709 in forum AutoCAD General
    Last Post: 2014-05-28, 08:25 PM
  3. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
  4. Lables not functioning Properly
    By Aquaserpent in forum AutoCAD Civil 3D - Alignments
    Last Post: 2007-03-15, 10:36 PM
  5. Custom font does not work properly in MTEXT or Dimensions
    By rharris51 in forum AutoCAD Customization
    Last Post: 2004-11-05, 01:06 AM
