Thread: RHS/SHS beam with edge plate
    2010-09
    4
    Default RHS/SHS beam with edge plate
    hi guys,
    I have to use RHS/SHS beam with edge plate to support a slab, but I could not find such beam in Revit Structure and Robot. I have attached a picture of it. Is there any way possible to use such a beam, so both Revit and Robot recognise it.
    2012-02
    97
    Default Re: RHS/SHS beam with edge plate
    I don't know how well custom profiles transfer from another program to another, usually I have encountered some problems. But if you need to calculate that kind of profile, I would model it in Robot without that edge plate and analyze it as standard RHS/SHS beam. If you need to consider stiffening caused by that edge plate then my first choice would be calculate by hand sectional properties of that section and then choose heavier standard RHS/SHS profile that has same sectional properties. That way you get displacements quite right in RObot calculations but section verification you have to do by hand calculations.
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Somerville, MA
    291
    You can use the section builder in Robot (Tools>Section Definition...) to create this custom built-up shape. Robot is quite adept at handling built-up shapes and it's not hard to add the shape to the database for use in a model. I've attached a couple images showing this type of section created and analyzed in section builder and also added to a model. (This was just quickly done for demonstration purposes, not rigorously). As far as I know there is no way to indicate exact location of welding which connects the sections together so there is still work for you to do in terms of chasing the loads through the section and ensuring that the welds are sufficient for the applied loads but Robot can help with overall section properties.
    I hope that helps.
    -Ken
    Ken Marsh
    Owner, Marsh API
  1. 2013: RHS/SHS beam with edge plate
    By lomo2002 in forum Revit Structure - General
    Last Post: 2013-05-06, 03:46 PM
  2. 2013: How to cut out the top of a Grade Beam for 2x6 plate!
    By Cosmic Traveller in forum Revit Structure - General
    Last Post: 2013-04-11, 06:53 PM
  3. Locking Floor edge to beam edge
    By djc1984 in forum Revit Structure - General
    Last Post: 2010-08-26, 09:01 PM
  4. adding plate to underside of beam
    By kathey1 in forum Revit Structure - General
    Last Post: 2009-07-29, 05:06 AM
  5. Beam with Hung plate
    By Galadriel in forum Revit Structure - General
    Last Post: 2008-02-11, 05:56 PM
Tags for this Thread
