Thread: RHS/SHS beam with edge plate
    2010-09
    4
    Default RHS/SHS beam with edge plate
    hi guys,
    I have to use RHS/SHS beam with edge plate to support a slab, but I could not find such beam in Revit Structure and Robot. I have attached a picture of it. Is there any way possible to use such a beam, so both Revit and Robot recognise it.
    2007-01
    226
    Default Re: RHS/SHS beam with edge plate
    you will need to make your own built-up member using the two elements in two steps, first the RHS shape and then the plate placed at bottom you should be able to find both of these two elements in the standard Revit family libraries. You could make a special custom beam family to combine the two together. I am not a Robot user, but I question if it would be wise to put effort into trying feed the built-up section properties into Robot for design. I have used some design programs that do have methods to input section properties for special built-up members. But I assume that this will be an eccentric load applied to this member and will require special torsional design of this member, I would be careful here. Maybe a Robot user can step in to give you some help here.
    I could stop if I wanted to kmarsh's Avatar
    2005-09
    Somerville, MA
    291
    As far as I know, at this point, there is no convenient way to facilitate round-tripping of custom built-up sections between Revit and Robot. You can manage this yourself of course but it's not automated. I could be totally wrong here because the Revit-Robot link surprises me quite often with its capabilities. However, Robot can definitely manage the custom section in terms of creating and analyzing the section properties as well as using it in the analysis and design (with some limitations). See my post in the Robot Structural Analysis forum for some images of that.
    Ken Marsh
    Owner, Marsh API
  1. 2013 RHS/SHS beam with edge plate
    By lomo2002 in forum Robot Structural Analysis
    Last Post: 2013-05-06, 03:31 PM
  2. 2013: How to cut out the top of a Grade Beam for 2x6 plate!
    By Cosmic Traveller in forum Revit Structure - General
    Last Post: 2013-04-11, 06:53 PM
  3. Locking Floor edge to beam edge
    By djc1984 in forum Revit Structure - General
    Last Post: 2010-08-26, 09:01 PM
  4. adding plate to underside of beam
    By kathey1 in forum Revit Structure - General
    Last Post: 2009-07-29, 05:06 AM
  5. Beam with Hung plate
    By Galadriel in forum Revit Structure - General
    Last Post: 2008-02-11, 05:56 PM
