Thread: Connection Between RC Column with Steel Bracing
    2011-09
    Exclamation Connection Between RC Column with Steel Bracing
    Hi all,
    unable to Notch or trim end connections Between RC Column & Steel Bracings
    find image attached
    Thanks in advance
    Regards
    Krishnakumar
    Last edited by krishnakumar; 2013-05-09 at 10:11 AM. Reason: unable to upload image
    2002-09
    Madison, WI
    5,687
    Default Re: Connection Between RC Column with Steel Bracing
    Are you trying to attach a steel vertical brace frame to a reinforced concrete column?
    Not sure what you're trying to do.
    To post/upload image, try to use a .png file.
    2011-09
    sorry,
    getting error, dont know how to do it
    any help will be appriciated
    yes, you are right, im trying to attach vertical steel bracing to a RC column
    Regards
    Krishnakumar
  1. Trouble Attaching Steel Column to Concrete Column Below
    By amiller.223744 in forum Revit Structure - General
    Last Post: 2009-09-02, 03:13 PM
  2. steel column connection visibility
    By ambrown178655 in forum Revit Structure - General
    Last Post: 2009-09-01, 12:49 PM
  3. Show steel X bracing as a single line in Fine Detail?
    By Dave F. in forum Revit Structure - General
    Last Post: 2009-03-18, 09:17 AM
  4. steel bracing visibitly issue
    By bskripac in forum Revit Architecture - General
    Last Post: 2007-11-07, 09:59 PM
