Results 1 to 10 of 14
Thread: New Weld Symbol
    2006-09
    442
    Default New Weld Symbol
    I have been getting complaints about the weld symbol in Revit being to long when we aren't showing all the information. So I took that weld symbol that had been developed by and another user (which I think know is the one that ships with Revit), and made some modifications to it, so that when we don't show weld lengths or stitch welds the length of the weld symbol gets smaller. I did this by added a new yes/no parameter that controls if you want to see the weld length. I also had to nest the tail label into the weld symbol family. I thought I would post it here is case anyone else wanted to use it.
    I made it a different name so you could distingue between the new and old. If you really wanted to get into it you can specify your own lengths. Also let me know if you have any suggestions to improve it.
    Blue Springs, MO
    658
    Default Re: New Weld Symbol
    I'm loading it as we speak. Good job!!! Now I'll have to do something about the size ot those symbols. They've always been HUGE. Why is that?
    2005-02
    4
    The weld symbol works nicely until I turn off either the field weld or the all-around or both. The line goes back to it's original length even though the weld symbol length parameter shows the shorter dimension. Is anyone else having this problem and if so, have you figured out how to fix it?
    2006-09
    442
    Aw yes I see what I you mean I will see if I can fix it.
    Update:
    I found what the problem was. Forgot to lock dimension. Here is new version. Let me know if that doesn't fix the problem for you.
    2005-02
    4
    I still could not get it to work right, so I played with the one I have. I added some invisible lines and grouped the symbols to the right. It seems to be working now. Thanks for you effort.
    2006-09
    442
    I also took a look at it and it seems to be working now. I am not sure what happened it use to work.
    2006-07
    130
    Dennis -
    Did you change any overall sizes of the sub-elements?
    - Patrick
    2006-09
    442
    Nope I left them as they are. I started to look at that but realized it was going to be more work than I initially thought. Are you looking to have them reduced also?
    2010-08
    9
    Is there a way to include the arrow head pointer into the weld symbol family. Similar to the arrow head when using Text (TX).
    2006-07
    130
    Nasser -
    When you place the weld symbol, you should be able to indicate the "Number of Leaders" you want. Also, if you forget to do that before placing the symbol, then once you've placed it, you can select the placed symbol and use the "Leader" area on the "Modify Generic Annotations" tab of the ribbon to add or remove leaders.
    HTH
  1. Annotation - Weld symbol
    By tiffany.amorgan in forum Dynamic Blocks - Sharing
    Last Post: 2012-08-15, 01:23 PM
  2. Weld symbol gap
    By matt__w in forum Revit Structure - General
    Last Post: 2010-07-26, 02:02 PM
  3. Help with weld symbol
    By REVIT_MONKEY in forum Revit Structure - Families
    Last Post: 2010-05-06, 09:49 PM
  4. Weld Symbol
    By David van Erk in forum AutoLISP
    Last Post: 2009-10-10, 06:12 PM
  5. Weld Symbol - Bottom Contour Symbol
    By kcooper.190440 in forum Revit Structure - Families
    Last Post: 2008-10-07, 07:21 PM
