Thread: AutoCAD Error Unhandled exception...Could not load file or assembly
    2015-11
    Dallas, Texas
    142
    Default AutoCAD Error Unhandled exception...Could not load file or assembly
    When I go into my CUI to edit/customize something I keep getting this error.
    Unhandled exception has occured in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
    Could not load file or assembly *System.Design. Version=4.0.0.0. Culture=neutral, PublicKey Token=b03f5f7f11d50a3a' or one of its dependencies. Signature specified is zero sized. (Exception from HRESULT: 0x80131237).
    Can someone please help. I have absolutely no idea.....
    Cairo - no, not Illinois
    5,069
    Default Re: AutoCAD Error Unhandled exception...Could not load file or assembly
    Try a Repair of the installation from Control Panel. If that doesn't cut, try doing a re-install from the same place. sounds like something got deleted/corrupted on your file system
    2015-11
    Dallas, Texas
    142
    I tried both and neither worked. Ugh! Now I've lost all of my customizations. That sucks.
    Any other ideas?
  1. Fatal Error: Unhandled Exception
    By dweber.150074 in forum AutoCAD General
    Last Post: 2007-11-13, 10:16 AM
  2. AutoCAD 2007 error - Unhandled c0000094h Exception at 691bf349h
    By JMonrex Gadgude in forum AutoCAD General
    Last Post: 2007-04-03, 12:52 PM
  3. Error: Unhandled Exception
    By matthewschwartz in forum Inventor - General
    Last Post: 2007-03-01, 12:51 AM
  4. Fatal Error: Unhandled Exception" Error Message
    By jkrulicki in forum MDT - General
    Last Post: 2004-07-28, 03:56 PM
