Results 1 to 1 of 1
Thread: SE104-2: Revit Structure Worksets 101
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE104-2: Revit Structure Worksets 101
    Instructor: Jamie Richardson
    Class Description: Worksets are enabled in Revit Structure when the project needs to be shared with multiple team members. And once enabled, users can check out individual elements or an entire Workset. All members of the design team can view these elements or Worksets in read-only mode, which prevents conflicts in the project. Team members adding and changing elements in Worksets can save their work to a personal location and publish work to a central file so others can see their latest changes. With the Reload Latest function, users can also update their local files at any time to view new changes. A better understanding of the process will help in the planning and execution of worksharing in a project environment.
    Worksets are enabled in Revit Structure when the project needs to be shared with multiple team members. And once enabled, users can check out individual elements or an entire Workset. All members of the design team can view these elements or Worksets in read-only mode, which prevents conflicts in the project. Team members adding and changing elements in Worksets can save their work to a personal location and publish work to a central file so others can see their latest changes. With the Reload Latest function, users can also update their local files at any time to view new changes. A better understanding of the process will help in the planning and execution of worksharing in a project environment. The Worksharing Monitor for Revit facilitates the use of Revit software in a worksharing environment, in which multiple people work on one project.
  1. SE104-1: Maximize the Use of Autodesk Revit Structure Extensions
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:49 AM
  2. SE104-3: Essential Autodesk Revit Structure Project Template Techniques
    Last Post: 2014-12-01, 03:35 AM
  3. SE104-1: Revit® Structure: Tips and Techniques for Production and Presentation
    By Autodesk University in forum Structural Engineering and Design
    Last Post: 2013-05-05, 02:18 AM
  4. Replies: 0
    Last Post: 2013-04-17, 04:38 AM
  5. Using Worksets with Revit Structure?
    By jrichardson in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-01-13, 03:19 AM
