Thread: Entourage Help
    Active Member kim.74445's Avatar
    79
    Default Entourage Help
    I am trying to use two vehicles I found in the Revit Entourage section (the Explorer and the Beetle) but I do not want them to show up as wireframe in plan view...is there a way to change this w/o having to turn on/off all of the layers of the object?
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Entourage Help
    I think all you need to do is open the file as a project. Delete the lines in plan view (that is why it looks to be wireframe, they are only 2d lines) make sure that you check the filter and deselect all but lines
    Then you need to select the 3d and change the visibility property to be "on" in plan view.
    2003-05
    5,153
    Luigi's method of modifying the visibility and symbolic lines within the family works, or alternatively, you can turn off entourage in the plan views vis graphics settings.
  1. 2013: entourage
    By scoe in forum Revit - Rendering
    Last Post: 2013-11-14, 03:26 PM
  2. entourage ...
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-11-27, 09:04 PM
  3. Entourage for MEP?
    By matt__w in forum Revit MEP - General
    Last Post: 2009-08-14, 12:15 PM
  4. Entourage?
    By joe.199382 in forum Revit - Rendering
    Last Post: 2008-12-15, 04:44 PM
  5. Entourage Help
    By kim.74445 in forum Revit Architecture - General
    Last Post: 2005-02-17, 09:58 PM
