Results 1 to 1 of 1
Thread: AB214-3: Opening the Door to Curtain Walls in AutoCAD® Architecture, Part II
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default AB214-3: Opening the Door to Curtain Walls in AutoCAD® Architecture, Part II
    Instructor: David Driver
    Class Description: This class builds on Part I. In this session, you’ll learn the appropriate use of overrides and how to add custom blocks to any portion of the Curtain Wall. We’ll also build a custom door/window assembly to illustrate the extreme flexibility of this object. A tips-and-tricks section will cover how to use the Curtain Wall objects to create entirely new types of objects such as casework and parking stalls.
  1. AB214-1V: Building Better in AutoCAD® Architecture 2011
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:58 PM
  2. Replies: 0
    Last Post: 2013-05-05, 03:21 AM
  3. Replies: 0
    Last Post: 2013-04-17, 04:46 AM
