Results 1 to 1 of 1
Thread: AB218-1L: A Quick Spin on Revit Architecture
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default AB218-1L: A Quick Spin on Revit Architecture
    Instructors: Cyril Verley and Robert Mencarini (Assistant) and David Harrington (Assistant)
    Class Description: For those of you who have never used Revit but always wanted to, now's your opportunity. In this session, we'll jump into Revit head first. This hands-on class will begin with Revit's user interface and focus on key Revit concepts that can be applied to many different features of the software. We'll then take a glimpse of Revit from all phases of the design process -- for schematic design, we'll trace an imported hand sketch; for design development, we'll create a plan color diagram; and for construction documents, we'll cut sections, make a callout, add dimensions, and place them all on a Sheet. We'll even link an AutoCAD detail into the project. If you want to see Revit up close for the first time, this class is for you.
  1. AB218-2L: A Quick Spin on Autodesk® Revit® Architecture Curtain Walls
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2014-11-30, 01:13 PM
  2. AB110-1L: A Quick Spin on Revit Architecture Curtain Walls
    By Autodesk University in forum Building Design
    Last Post: 2013-05-05, 03:14 AM
  3. AB104-5L: A Quick Spin on Revit Architecture Curtain Walls
  4. AB100-1L: A Quick Spin on Revit Architecture
    Last Post: 2013-05-05, 03:12 AM
