Results 1 to 10 of 14
Thread: FM Class handouts from AU and RTC
    2001-12
    St. Louis
    5,230
    Post FM Class handouts from AU and RTC
    Members of AUGI, you'll notice that the AU class handouts are being added to the forums (must be logged in to download the files). I'm going to link to the classes, just to have a pointer directly to them.
    Even if there isn't an FM track for a year of AU handouts, I'd still recommend that you check out the CAD Management and Programming coursework. Obviously, when you work on a huge scale like in CAFM, you can benefit from automation and standardization tips and tricks and code snippets.
    Autodesk University 2002 - Facilities Management Track:
    FM23-1: Developing a FM Automation Program for AutoCAD - A Real World Example!
    Instructors: Brian M. Wildt (wildtb@weasler.com) and Phil A. Leverault and Dave Espinosa-Aguilar
    Class Description: In this course we\'ll show you how we developed an automation program from concept to implementation. We\'ll discuss how to get started, what things to keep in mind as the concept gets off the ground and a few problems that you may run into. We know there are many companies out there looking for ways to save time and money in their drafting departments. We want to share our experience with you and show you just what can be accomplished and maybe give you some ideas to get started with a program of your own.
    FM33-1: FM Desktop™ Leveraging AutoCAD to Meet Your Facility Management Needs…
    Instructor: Bob Fahlin
    Class Description: Using FM Desktop™ and Autodesk® technologies to return sanity to the chaos that is facility management.
    FM34-1: Facility Management Made Easy with faciliCAD
    Instructor: Bill Kilp
    Class Description: Needs Analysis, Existing Data Review, Software Selection, Data Input, Data Extraction, Data Management and Software Maintenance are all phases of implementing a facility management system. Each of these topics could be a class in itself. The intent of this course is to give the student a bird’s eye view of the process from the early stages of conceptual meetings, to implementation and use of the system. The main focus will be on data entry. We will discuss the minimum requirements for creating space chargeback reports to entering additional data such as employees and assets. We will cover the basic steps necessary to attach and link CAD floor plans to an external database using faciliCAD. The combination of faciliCAD and AutoDesk’s AutoCAD, Architectural Desktop or AutoCAD Map, gives the user all the tools needed to create graphic and non-graphic Space, Employee and Assets reports.
    2001-12
    St. Louis
    5,230
    Default Re: FM Class handouts from AU and RTC
    Autodesk University 2003 - Facilities Management Track:
    FM12-1L: Introduction to dbConnect for Facilities Management
    Instructor: Scott McFarlane
    Class Description: This hands-on lab will give you a jump-start into the world of database connectivity. Learn how to set up a database connection, create links, and turn your drawing into a powerful interface to your database. Explore the dbConnect Manager and the Data View window and create intelligent annotation using Labels. Create simple and even complex queries with the Query Editor.
    FM13-1: From CAD to CEO with Autodesk and ARCHIBUS/FM
    Instructor: Gregory J. Alevras
    Class Description:
    About ARCHIBUS, Inc.
    Why Automate Facilities
    FM31-1: Digging Deep into Databases
    Class Description: This session takes a holistic approach to the topic of database integration with AutoCAD. Rather than focusing only on the tools (such as dbConnect), we will examine all the issues that you are faced with when integrating a CAD system with a database system. You will learn the fundamentals of database design and SQL, and study real-world examples that show how important these skills are to the success of your application. This session will also explore how development environments, such as VBA, can be used to extend the built-in features. We will combine this knowledge with the use of AutoCAD and dbConnect to develop a complete application from start to finish.
    FM32-1: ChargeBack Reports: From CAD Drawing to Database Report
    Class Description: When budget time comes around one of the goals of any facility manager is to produce a chargeback report. This session will analyze all the elements required to produce chargeback reports. We'll use AutoCAD 2004 to define the methods for outlining the spaces, faciliCAD v2 for the database data entry of room information, and Crystal Reports for the final report.
    FM33-1: Autodesk Map and Autodesk MapGuide for Facilities Management
    Instructor: Barry Kelly
    Class Description: This session will address both inside and outside plant FM requirements. Most facilities management drawings are not spatially referenced, a factor that can impact the use of Autodesk Map and Autodesk MapGuide. You will learn tips and tricks for this environment.
    2001-12
    St. Louis
    5,230
    Autodesk University 2004 - Facilities Management Track:
    FM23-1L: Introduction to dbConnect for Facilities Management
    Instructors: Scott McFarlane – SHM Development, Inc.
    Class Description: This hands-on lab will give you a jump start into the world of database connectivity. Learn how to set up a database connection, create links, and turn your drawing into a powerful interface to your database. Explore the dbConnect Manager and the Data View window and create intelligent annotation using Labels. Create simple and even complex queries with the Query Editor. This class is designed for facility managers who use AutoCAD® and want a jump start into the DbConnect user interface.
    FM31-1: From Architectural Desktop to Facility Management Reports
    Instructors: Bill Kilp – faciliCAD LLC and John Janzen – faciliCAD LLC
    Class Description: Learn to use Autodesk Architectural Desktop and faciliCAD V2 to connect CAD drawings with a Microsoft SQL database, harnessing the power of Architectural Desktop with facility management-specific features. Link Space and Area objects to database records to transform Architectural Desktop drawings into intelligent resources, extending their value beyond the design phase throughout the life of the building. Learn to create a live database link between architectural Space and Area objects to records in an SQL Database. Changes in the database affect the CAD drawing and vice versa.
    FM33-1: Publish Building FM Information to the Web Using Autodesk MapGuide®
    Instructors: Bill Kilp – faciliCAD LLC and Glenn Stazak – Stazak Consulting Services
    Class Description: Building Lifecycle Information can be entered, accessed, and edited within an AutoCAD® or Autodesk® Architectural Desktop drawing and published to a customizable web-based environment using Autodesk MapGuide technology and faciliCAD. Use MapGuide to view and report on space, people, and asset information from a web-based format that requires virtually no learning curve. This class is designed for CAD managers and users. It will be somewhat technical but interesting for its simplicity.
    FM41-1: Digging Deep into Databases
    Class Description: This session takes a holistic approach to the topic of database integration with AutoCAD®. Rather than focusing only on the tools (such as dbConnect), we will examine all the issues that you are faced with when integrating a CAD system with a database system. You will learn the fundamentals of database design and SQL, and study real-world examples that show how important these skills are to the success of your application. This session will also explore how development environments, such as VBA, can be used to extend the built-in features. We will combine this knowledge with the use of AutoCAD and dbConnect to develop a complete application from start to finish. This class is designed for anyone who is beginning to work with the database connectivity features of AutoCAD, but may not have a strong foundation of database knowledge.
    2001-12
    St. Louis
    5,230
    Autodesk University 2005 - Facilities Management Track:
    FM34-1L: Introduction to dbConnect for Facilities Management
    Instructors: Scott McFarlane and Bill Kimbrell (Assistant); Jimmy Bergmark (Assistant)
    FM33-1: dbConnect for Facilities Management
    Class Description: Facilities Management is a complex, multifaceted field. It is no surprise that commercial off-the-shelf software geared toward FM tends to be equally complex, and often demands steep learning curves. For many of us, however, AutoCAD’s built in dbConnect functionality provides a suitable alternative for meeting the needs of the typical facilities manager. This class provides an introduction to dbConnect, and shows how this technology can be used to accomplish specific FM tasks. We will explore the built-in capabilities of the dbConnect user interface, as well as demonstrate some simple, yet powerful custom macros that offer more advanced functionality.
    FM22-1: Autodesk Architectural Desktop: The Facility Manager's Dream
    Instructor: David Shepherd
    Class Description: The combination of new Architectural Desktop 2006 features, such as Display Themes and Database Fields, together with ADT Areas, Spaces, and Scheduling make the software a formidable out-of-thebox solution for facility managers. This session will demonstrate how easily room booking, asset tracking, and lease chargeback data can be linked into ADT 2006 without complex programming or recourse to third-party applications.
    FM13-1: DWF and Effective Facility Information Management
    Instructor: Robert Fahlin
    Class Description: Learn how to unleash the power of DWF to address the facility information management and documentation needs of your organization. Learn how embedded Autodesk technologies can provide an end-to-end solution for CAD operators, administrators, and others responsible for the management and dissemination of facility information. DWF provides the catalyst to bring facility drawings and data together in an easy-to-access format.
    FM12-2: Tips and Tricks for Evaluating, Selecting, and Implementing a CAFM Solution
    Class Description: The following are all phases of implementing a facility management system: needs analysis, existing data review, software selection, data input, data extraction, data management, and software maintenance. Each of these topics could be a class in itself. The intent of this course is to give attendees a bird’s-eye view of the process from the early stages of conceptual meetings, to implementation and use of the system. The main focus will be on data entry. We will discuss the minimum requirements for creating space chargeback reports to entering additional data such as employees and assets.
    FM11-2: Chargeback Reports: From CAD Drawings to Database Report
    Class Description: When budget time comes around, one of the goals of any facility manager is to produce a chargeback report. This session will analyze all the elements required to produce chargeback reports. We will uncover the mystique surrounding the ANSI BOMA and IFMA documents defining Standard Methods for Measuring Floor Area. We will use AutoCAD 2006 to define the methods for outlining the spaces using Polyline as the space boundaries. Once defined, these boundaries can be linked to a database using a third-party CAFM solution.
    2001-12
    St. Louis
    5,230
    Autodesk University 2006 - Facilities Management Track:
    FM11-1: Make FM Part of Your AutoCAD® World
    Instructor: Shaun Bryant - STJ2 Constultants Ltd.
    Class Description: This session focuses on how a computer-based FM system can enhance your AutoCAD facilities drawings. We’ll demonstrate how easy it is to implement an integrated FM system with your existing AutoCAD drawings and data. We’ll present insights into how to prepare your existing drawings for the move to an FM system and how to link them to that system. We’ll also demonstrate the benefits and productivity gains that can be achieved. This session is for intermediate and seasoned AutoCAD users who have yet to move to an integrated FM system. Users of any version of AutoCAD who want to enhance their understanding of proprietary facilities management systems and AutoCAD will benefit from this in-depth session. Some prior experience of facilities management will be helpful.
    FM12-1: Facility Management Handbook
    Instructors: Bob Fahlin - Autodesk, Inc.
    Class Description: This session is designed to be a primer for all those involved in the management of the facility environment. Attendees will review a summary of issues and challenges that face today’s facility professionals. Learn how to manage space occupancy and allocation information. Understand how facility infrastructure can impact the workplace. See how Autodesk is helping facility management professionals step up to the challenges with world-class solutions and advanced technologies.
    FM22-1: Digging Deep into Databases [Part 1]
    Instructors: Scott McFarlane - Geotropix, Inc.
    FM24-1: From Blue Line to Bottom Line Using Autodesk® FMDesktop
    Instructors: Matt Davoren - CADD Microsystems, Inc.
    Class Description: The technology aspect of facilities management is critical to maintaining an organization’s infrastructure to support the overall business objectives, but where do you get started? This is a crucial part of a facility manager’s strategic plan. By utilizing Autodesk newest solution, FM Desktop, your company can avoid the classic mistakes and post-implementation blues that can occur when a maintenance plan for people and systems is not in place. Don’t miss this opportunity to learn about technology’s role in making you better in Facility Management.
    2001-12
    St. Louis
    5,230
    Autodesk University 2007 - Facility Management Track:
    FM500-1: Autodesk FMDesktop from CAD to the Web
    Class Description: This session is a comprehensive FMDesktop workshop that covers all the components of Autodesk FMDesktop, a computer aided facility management (CAFM) suite of products. You will learn how to take a static drawing and turn it into a powerful facility management tool using Facility Manager, the FMDesktop component that provides space allocation reporting, occupancy assignments, and move management. You will learn how to publish your facility management information to your corporate intranet or the Web in minutes using Facility Web. This session is designed for facility management professionals familiar with basic CAFM concepts. CAD expertise is not required for this session.
    FM318-1: Using Autodesk FMDesktop in the Real World
    Instructor: Arthur Franz
    Class Description: Learn how the flexible structure in Autodesk FMDesktop allows you to apply its toolset to solve facilities issues. In this session, you'll discover how to add User Definable Fields (UDF) to store data unique to your facility; produce graphical thematic reports with Dynamic Hatching to show reports such as classroom utilization, contractor and intern seats, floor finishes, and room types; and how to define distribution systems for your facilities infrastructure using Service and Dependant relationships. We'll also use examples in our discussion on how computer equipment is affected when you take down a router and identifying which thermostat controls the temperature of a specific room.
    FM314-1: Revit Architecture and Autodesk FMDesktop: The "Dynamic Duo" of Facilities Management
    Instructor: Clyne Curtis
    Class Description: This session will introduce management professionals, architects, and space planners to the powerful relationship that exists when parametric software (Revit Architecture) integrates with facilities management software (Autodesk FMDesktop). You’ll learn how to leverage your BIM model and facilities data into a supercharged facilities management tool. We’ll explore how to create up-to-date space, asset, occupancy, and move-management information for your facility or campus and learn how to present that information to end users with an extremely user-friendly interface. Real-world examples of linking Brigham Young University campus buildings in Revit Architecture to Autodesk FMDesktop will be used to highlight the power of this dynamic software duo!
    FM304-1: Detailed Reporting in Autodesk® FMDesktop™
    Instructor: Jon Luby
    Class Description: With the help of the Autodesk FMDesktop software suite, this class will delve into the reporting capabilities within Facility Manager. Utilizing Drawing Queries, Facility Reporting, and Dynamic Reports, we’ll showcase how to retrieve, filter, and customize reporting requirements.
    FM300-1: Complying with the U.S. National CAD Standard: Do Your Drawings Comply?
    Instructors: Rick Green, FCSI, CCS, CCCA, AIA, LEED AP
    Class Description: This class provides in-depth coverage of Unite States National CAD Standard (NCS) requirements that owners, facilities managers, and government agencies are now requiring for their construction drawings. This session includes workshop-style hands-on exercises that will cover many of the most common compliancy errors, and how to avoid them. The class includes examples of NCS-compliant drawings and strategies that can be referred to when implementing the NCS into the workplace. If you need to know more about NCS drawings and how to save time creating them, this class is for you.
    FM218-1: Implementing an FM Product with Your AutoCAD® Drawings and Block Data
    Class Description: This session is for intermediate as well as seasoned AutoCAD users. We’ll demonstrate how to easily implement an FM product with your existing AutoCAD drawings and block data. You’ll learn how to use your existing AutoCAD block inventory to create a furniture and equipment inventory both on your drawings and in your FM system’s database. We’ll also demonstrate the benefits and productivity gains that can be made. Users of any version of AutoCAD who want to enhance their understanding of facilities management systems and AutoCAD will benefit from this in-depth session. Some prior experience of facilities management will be helpful.
    FM210-1: Don’t Get Floored in your Facility: From Revit® Architecture to Autodesk® FMDesktop™
    Instructors: Matt Davoren and Christopher Fernandez
    Class Description: There has never been a better time to utilize the powerful tools to design, build, and maintain a building and its life cycle. Learn how to create Revit Architecture building information models that you can then transfer to Autodesk FMDesktop with minimal effort. By exporting to spreadsheets of information and utilizing templates, you can easily import into FMDesktop. This allows facilities managers to track people, places, and things in a user-friendly environment.
    Creating parameters in Revit for rooms
    Scheduling the room objects, and more
    Exporting the schedule to delimited files
    Importing into FMDesktop
    The ease of use and functionality in FMDesktop
    FM204-1: Facility Management Handbook
    Class Description: This session is designed to be a primer for all those involved in the management of the facility environment. Attendees will review a summary of issues and challenges that face today's facility professionals. Learn how to manage space occupancy and allocation information. Understand how facility infrastructure can impact the workplace. See how Autodesk is helping facility management professionals' step up to the challenges with world-class solutions and advanced technologies, easy enough to be used by the novice, yet powerful enough to meet the demands of even the most demanding facility management veterans.
    FM110-1: Using Autodesk DWF in Facilities Management
    Instructor: Mark Evans
    Class Description: This session demonstrates how DWF can be used to increase productivity in various facilities management tasks. Autodesk Design Review can be used to review, measure, and mark up drawings created for facilities construction, management, operations, renovation, and even demolition. Facilities managers or other facilities professionals can review drawings submitted by architects, engineers, or construction professionals. Facilities managers using Autodesk FMDesktop can create DWF drawings to share with their facility occupants or with service providers. This session demonstrates the power of Autodesk Design Review when used in conjunction with Autodesk building design applications and facilities management applications. It will also show how Autodesk Freewheel can be used to share DWF files without installing a viewer.
    FM104-1: Using Autodesk® FMDesktop for Space Management on a Shoestring Budget
    Instructor: James E. (Jimmy) Niles
    Class Description: This class will introduce the process and procedures to implement a space management system on a limited budget. We will explore the use of Autodesk FMDesktop to track departments, research grants, employees, room use, and more, for any size organization (whether it is 10,000 or 10 million square feet). We will also discuss how to make information readily available over the intranet or Internet by using third-party off-the-shelf products.
    2001-12
    St. Louis
    5,230
    The Revit Technology Conference (RTC) handouts will be hosted on the forums as well, so I took a quick browse through the first set available to find some classes I feel are applicable to the post-construction set.
    RTC Australasia 2011
    Session 2:
    Revit Protocols and Standards - Where do I start?
    http://forums.augi.com/showthread.ph...ere-Do-I-Start
    Session 3:
    Still not sharing your coordinates?
    http://forums.augi.com/showthread.ph...ur-Coordinates
    Session 4:
    BIM - from the ashes rose the phoenix (IPD + and - on a $100m project)
    http://forums.augi.com/showthread.ph...-the-phoenix
    Topography - the highs and lows
    http://forums.augi.com/showthread.ph...hs-and-lows!
    Session 5:
    10 Free Revit Add-ons you can't live without
    http://forums.augi.com/showthread.ph...t-live-without
    Session 6:
    Training Your Staff
    http://forums.augi.com/showthread.ph...ing-your-staff
    Session 7:
    Beyond Buildings - Master Planning with Revit Architecture
    http://forums.augi.com/showthread.ph...t-Architecture
    Drop the B in BIM - how projects can benefit from IM, infrastructure or plants
    http://forums.augi.com/showthread.ph...p-the-B-in-BIM
    Understanding BIMWashing (how to spot it)
    http://forums.augi.com/showthread.ph...vice-Providers
    Case Study - Multi-disciplinary Clinic Project
    http://forums.augi.com/showthread.ph...Clinic-Project
    Master Planning Communities
    http://forums.augi.com/showthread.ph...ng-Communities
    Session 10:
    BIM & Healthcare: Caring is NOT Sharing
    http://forums.augi.com/showthread.ph...IS-NOT-Sharing
    Bringing BIM to the Site
    http://forums.augi.com/showthread.ph...IM-to-the-site
    Revit Collaboration Case Study
    http://forums.augi.com/showthread.ph...uot-Case-Study
    2001-12
    St. Louis
    5,230
    I just ran across this post of mine from AU2006, covering a panel discussion, so there would be no course handout.
    http://mistressofthedorkness.blogspo...sful-cafm.html
    Keys to a Successful CAFM Implementation
    Denise Cahill from Cahill Consultants
    Shaun Bryant from CAD/FM Consultants Ltd
    Aaron Bukowitz from Avatech
    Matt Davoren from CADD Microsystems
    David Jordani from Jordani Consulting Group
    and was mediated by Mark Evans from Autodesk BSD
    Good topics include:
    Most Vital Components for a Successful Implementation
    Best Practices
    Steps During Implementation
    Awareness, Standardization
    Quote Originally Posted by Wanderer View Post
    2001-12
    St. Louis
    5,230
    RTC North America 2011
    Session 2, Part B: Providing Revit Help Desk Support in a Larger Office
    Instructors: Daniel John Stine, LHB
    Class Description: This session is meant to help increase your resolution efficiency and value to an AEC firm. Many topics will be covered including; prioritizing multiple issues, dealing with overly dependent users, standards enforcement, and much more. Several real-world type problems will be outlined and resolved during the presentation.
    Session 2, Part A/B: Revit MEP Plumbing - Mystery Solved
    Instructors: Plamen Hristov, Capital Engineering Consultants, Inc
    Class Description: There are way too many comments and discussions about Plumbing in Revit MEP and how it doesn't work. Well, I would like to invite you to a class where you are going to do plumbing design yourself. During this hands-on class we are going to discuss what kind of challenges we are facing when using Revit MEP for plumbing and find feasible solutions. We are going to discuss the necessary detail level, the appropriate workflow between the architect and the plumbing designer, and of course the documentation that we need to produce.
    Session 2, Part A: Using a Revit Model in Engineering Analysis & Design
    Instructors: Desiree Ratley, PE, Martin/Martin
    Class Description: This class will demonstrate how to use a relatively new tool in Revit, reporting parameters, along with some classic tools, such as schedules and filters, to utilize a structural Revit model in the design and analysis phase of a project. All of these tools will be incorporated into one specific, comprehensive example.
    Session 2, Part B: Revit + Ecotect - A Green Relationship
    Instructors: David Haynes, AIA, LEED AP, Ideate, Inc.
    Class Description: Studies show that most crucial decisions happen in the first moments of the design process. Architects need tools that will asset them in the creating better and more sustainable building projects. This lecture will focus on which tools are available, when to use them, and how to get the maximum benefit from these energy analysis tools. To make better, more energy efficient, sustainable buildings, we need to make better strategic decisions early. Architects need tools that will assist them in creating better and more sustainable projects. This lecture will focus on which fools are available, when to use them, and how to get the maximum benefit from these energy analysis tools. To make better, more efficient, sustainable buildings, we need to make better strategic decisions early.
    Session 3, Part B: Solving Common Autodesk Revit Problems
    Instructors: Harlan Brumm, Autodesk, Inc.
    Class Description: Learn how to diagnose and troubleshoot the most common and frustrating problems that can affect Revit projects. This class will include troubleshooting views, families, work-sharing, memory related problems, and rendering problems. We will examine error messages in Revit and explore their causes and possible resolutions.
    Session 4: Maximizing your Schedules Potential
    Instructors: Ken Marcus, RFI Consultants Inc. with David Banyard, Modulus Consulting
    Class Description: This class will teach students how to build use schedules for more then just counting building components. During this class, we will show students how to develop an Occupancy Schedule that uses a Key Schedule to select room use types that determine Occupancy load numbers. Students will develop a key schedule that used integer-based values, then run formulas that will determine room occupancy, load factors and number of exits. Students will learn to build formulas, calculated values, and parameters so that calculated values will be run in the schedule. Occupancy tags will be created using shared parameters that will used in the schedule Occupancy numbers can be shown in a room tag. Also, we will cover how to round up in formula properly, mix and match different parameter types (area and integer), check if a calculated value matches a equivalent manual value in a tag to eliminate potential errors, and highlight errors for easy detection.
    Session 5: Facilities Management with Revit Architecture: What's in Your Tool Box?
    Instructors: Clyne Curtis, Brigham Young University
    Class Description: This lab class will introduce management professionals, architects, and space planners to the powerful tool set within Autodesk Revit Architecture that can be used to accurately and efficiently generate, maintain, and present facility data. Learn how to leverage project and shared parameters, rooms, area plans, color schemes, schedules, to provide up-to-date data for your end users. Explore the DBLink utility which will allow you to update parameters such as costs, life cycle information, and much more using an external database linked to your Autodesk Revit Architecture project.
    Session 6, Part B: How to Establish a BIM Project Execution Plan to Better Assist Your IPD Projects
    Instructors: Doug Williams, Perkins+Will
    Class Description: Now that Integrated Project Delivery (IPD) has become relevant in the A/E/C Industry, guidelines necessary to craft a BIM Project Execution Plan are becoming indispensable tools. This session will guide you through the process of establishing a plan to better assist your design and construction team in fully utilizing BIM to its maximum potential for your clients.
    This must have roadmap will define the appropriate uses of BIM for your projects throughout its lifecycle. It is my intent to share my practical experience of creating a document to ultimately serve as a template for your firm’s projects. Resources that were initially used to establish a plan to complement/integrate with your contracts will also be covered.
    Session 6, Part B: Codebook and Revit = BIM Lifecycle Management
    Instructors: Cyril Verley, RA, President, CDV Systems, Inc. with Daniel Stonecipher, Vice President, CDV Systems, Inc.
    Class Description: CodeBook is a software program based on Access and SQL and is used to manage a building's program, equipment, furniture and lifecycle needs. It is a standalone database application that links the project program & equipment requirements to Autodesk Revit Arch and MEP.
    2001-12
    St. Louis
    5,230
    RTC NA 2011 Part 2
    Session 7, Part B: Revit Collaboration & a "One Model" Case Study
    Instructors: Chris Price, Cadway Projects
    Class Description: Revit multi-discipline and interoffice collaboration is becoming more and more common in the industry. So what are the tricks to getting it all to work seamlessly? I will be addressing the various issues you will face, best practices as well as the different ways to achieve a successful outcome.
    Revit Server
    Copy/Monitor
    Coordination Review
    Linking / Coordinates
    File Exchange
    Communication Methods
    Session 7, Part A: Revit for Urban Design
    Instructors: Lee Miller, HOK
    Class Description: Revit for Urban Design will present a methodology that can enable project teams to quickly become efficient in a coordinated spatial environment that has computable information. The class will demonstrate a developed and documented process that connects the usually disparate and disconnected pieces of the urban design and master planning puzzles. Centered on these disciplines, the class is of value to all those in the design and decision making process.
    Session 9: Advanced Scheduling
    Instructors: Brian Mackey, CAD-1
    Class Description: We all know the “I” in “BIM” stands for Information, but how can you use that information to your advantage while working on projects? This class will show you how to use schedules to make sure you are staying within budget, use schedules to parametrically change values in objects already in the project, and how to gain access to data you may be unsure how to get. You will learn that schedules have a dual purpose.
    Session 9: Leveraging the Model Post Construction
    Instructors: Josh Lowe, TURIS
    Class Description: When BIM Models are given to the owner’s at the end of the construction, most owners have no plans to use. We will focus how models can save substantial time and money post construction; with an example from the Health Care community. This will demonstrate how a properly prepared model can effectively allow an owner to use the model to manage information through the life of the building.
    We will show how maintaining existing documents is easier with Revit. We will highlight the waste that exists currently during the document maintenance process for an owner. Additionally, we will discuss what other uses for the model are. We will show how we can use the model to make better expenditure decisions to maximize payback of investments in modelling.
    Session 10, Part A: Building a Dynamic Facility Management Web Application with Revit Using APIs
    Instructors: Don Rudder, HOK San Francisco
    Class Description: Building owners deserve a BIM product that they can utilize in their day-to-day operations. Shifting the completed Revit® BIM model and associated data into a light-weight, data rich web portal is the answer. This class will provide people of various backgrounds an overview on how the Revit .NET API and ASP.NET can be coupled into a dynamic FM possibility.
    Session 10, Part A: Revit Project Planning: The DIALOG Experience with the Calgary International Airport
    Instructors: Bruce McCallum, DIALOG
    Class Description: We will discuss what some of the early decisions and reasons for them. We’ll also cover how we corrected some of those decisions with better planning. After attending this class, you should have the ability to:
    Plan for a large project.
    Understand some of the challenges to watch out for when splitting a project while underway.
    How to document a project through linked files.
  1. Free Facilities Management Class Handouts
    By Mike.Perry in forum Facilities Management In Practice
    Last Post: 2009-09-24, 07:02 AM
  2. Replies: 2
    Last Post: 2007-06-21, 01:13 PM
  3. "Class description isn't identical with registered class"
    By sinc in forum AutoCAD Map 3D - General
    Last Post: 2007-01-22, 06:39 AM
