Results 1 to 1 of 1
Thread: (Help) delete some in-place mass divided surface triangular curtain panel?
    2012-12
    2
    Default (Help) delete some in-place mass divided surface triangular curtain panel?
    Hi guys, I really need a help to finish my final project, so I start a new project with massing in-place mass (pic 1), a semi dome building , by using divided surface, I load a panel triangular like space frame family(triangular flat pattern) (pic 2), use wall by face to fill the empty space, it worked just fine but then I need an opening in front of the building (pic 3), I was trying to use edit in place then created void but it didn't work.. I'm fine with the imperfection of the openingIs there anything I can do to delete some of the triangular panel family, or is there any better way to make an opening using edit in place? thanks in advance guys, oh btw I'm using revit architecture 2012.. All the help will be appreciated, thank you in advance guys!
  1. 2015: divided path "mass" with In-Place mass
    By tkunsman in forum Revit - Conceptual Design Tools
    Last Post: 2015-02-18, 06:16 PM
  2. 2014: Divided Surface Alignment Issue (to Adjacent Divided Surfaces)
    By TAmtb11 in forum Revit Architecture - General
    Last Post: 2013-11-15, 03:00 PM
  3. 2012: (Help) delete some in-place mass divided surface triangular curtain panel?
    By blackmamba9148 in forum Revit Architecture - General
    Last Post: 2013-05-13, 09:52 PM
  4. Replies: 1
    Last Post: 2012-04-25, 03:28 PM
  5. Replies: 10
    Last Post: 2010-08-25, 12:57 PM
