Thread: install both Autodesk Product Design Suite Standard 2013 & Architecture 2011
    2010-06
    57
    Question install both Autodesk Product Design Suite Standard 2013 & Architecture 2011
    Hi I'm hoping someone can give me some guidance/answers to this.
    I am currently using Autodesk Product Design Suite Standard 2013. I have also been asked to support one of our other major projects who have very strict cad standards.
    The requirement they have is that we useAutocad Architecture 2011. I can ( I think) download that from our central website. What I need to try & understand is what major headaches am I going to give myself if I have both sets of software loaded? I know I can only use one at any given time but am I going to get any problems you Guys know about if I open one & then the other etc.
    Just wondering about both software & licence conflicts. We use a global licence so the software just grabs one if available.
    Thanks for any advice help in adavance.
    TN/KY Area
    1,640
    Default Re: install both Autodesk Product Design Suite Standard 2013 & Architecture 2011
    You should have no problems as long as you keep each dwg/project in its correct version. Side by side installs does work, when I was doing support with a VAR I had a number of different versions and apps installed. Just make sure you open the application then open the dwgs and don't use windows explorer to open the files.
    2010-06
    57
    Thank you
    I thought I should be able to but wanted to be aware of any potential problems.
    I will have to remember what you said about opening the programme then the drawing though as it's so easy to open from explorer!
    Many thanks again for your input
    2001-12
    St. Louis
    5,406
    Quote Originally Posted by lesleys View Post
    Thank you
    Heh, I'm an explorer fan myself, too, I understand.
    I've typically got three or four versions installed at once, I can't remember having a problem with it. Currently, it's AutoCAD MEP 2011-2013 here and 2011-2014 at home, and no issues (hmm, that tells me it's time to upgrade pc's in both places! lol).
    Melanie Stone
    @MistresDorkness
    Technical Editor
    0,0,0 The Origin
    8,570
    If you (anyone) must use explorer to open files, remember that, when there is no acad-based application open, the LAST-CLOSED version will be the default.
  1. Replies: 1
    Last Post: 2015-09-10, 07:05 PM
  2. AB220-4: Beyond Massing: Conceptual Design Tools in Autodesk® Revit® Architecture 2011
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:48 PM
  3. 2013: Issues re-installing Product Design Suite 2013
    By allenjl in forum Inventor - General
    Last Post: 2013-07-18, 09:09 AM
  4. Inventor Product Design Suite Premium 2013
    By jimmy.long in forum CAD Management - General
    Last Post: 2013-06-24, 03:16 PM
  5. Revit 2013 (Design Suite) VS. Revit Architecture
    By Revitaoist in forum Revit Architecture - General
    Last Post: 2012-05-24, 11:15 AM
