Results 1 to 7 of 7
Thread: Measure questions
    2013-05
    4
    Default Measure questions
    Hello,
    We'd like to know if you can actually measure threads with Design review or anyway to do so. We sometimes need to use the DWF file on production line to measure things up.
    If not, is there a IDW viewer that would permit such measurements ? Or do anyone have an idea how we could achieve our goal without having to use Inventor.
    Thank you
    2013-05
    4
    Default Re: Measure questions
    Does anyone have the answer ?
    Thank you
    2001-12
    St. Louis
    5,410
    Threads? Like the length of a thread on a screw?
    I do not believe this is possible, the measuring options do not seem to be flexible enough to achieve it.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2013-05
    4
    Quote Originally Posted by Wanderer View Post
    Thread with size, pitch and lenght, like 1/2-13 x 1/2
    And as you say, sadly, DR does not seems flexible enough.
    Thank you
    2005-06
    in the upper right corner
    3,510
    What other options do you have available?
    Like do have, and can you use AutoCAD?
    Can the sheet(s) be exported out as a .dwg or .dxf and you could pull dims off of that?
    Just a thought
    2013-05
    4
    Just a thought
    We cannot use Autocad, for we would not have enough licenses for it and what we need to do, and our mechanics would not have the necessary training to use autocad. Our conceptors use Inventor and generate DWF files. We use Design review for 2 main reasons.
    #1 We only send dwf files to external companies that will make our parts. Lightweight and easy to gather different files into a merged file is great to send out quotes.
    #2 When production is on it's way, whether it be here at our main facility or at client upon installation, dwf files are light weight, DR is a lightweight program also (compared to trueview, I don't have a wimpy comptuer and TV takes a few minutes to load). 3D rendering of the machine is often used which DR does perfectly. The only down side is all (or lack of) the measuring tolls provided with DR.
    If anyone has any other suggestion or way of doing things we have overlooked, feel free to write
    Thank you
    2005-06
    3,510
    Ahh, understood.
    I don't have an actual solution, and I don't know a lot about DR, but
    In my experience, in Inventor: threads are an applied "feature" and not necessily "modeled".
    So when adding threaded holes or bolts & threaded rods, those aren't something you can "measure" but "smart features" that inventor tells you what they are.
    Unless I'm mistaken, and I could be....
    So does DR have the ability to get that info?
    Either that, or have your designers annotate the heck out of it for manufacturing purposes!
    Just something else to consider.
  1. 2014: 2 stair questions and 1 general coordination questions
    By utakecare2003 in forum Revit Architecture - General
    Last Post: 2014-08-16, 09:55 PM
  2. Measure and Paste
    By theald in forum AutoLISP
    Last Post: 2008-12-17, 04:49 PM
  3. Drafting Questions (was>(Stupid) Newbie Questions)
    By Andrew Dobson in forum Revit Architecture - General
    Last Post: 2005-05-12, 09:01 PM
  4. Measure tolerance
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2005-03-09, 04:04 PM
