Hi All: Wonder if you can help me.
I have been using the Transparency feature for making hatches see through over top other objects. (like text, lines etc.) The feature prints fine when I select the "Plot Transparency" check box.
The problem is when I close the file, and open it later, the hatches do not show up transparent. Even though they still print fine. Is the a configuration setting that I need to turn on so I can continue to view the transparency value on screen?
Thanks for your help.
- J
