Hi All
I have a dynamic symbol that reperesents our smoke detectors which has multiple visability states. No problems with the block but I now have a set of drawings where I need to change some blocks visability.
For example 100 detectors
10 at vis A
20 at vis B
70 at vis C
Is there a quick way to say change the 20 at Vis B to Vis A without having to go to each one?
Looked at Quick select but there is no option for visability state which would have been ideal. I also looked at trying to use the find & replace as it has an attribute but though it found them all & I had hoped I could use that.
I'm sure it could be done using lisp but unfortunatly its not something I have ever got to grips with. Any ideas or one for the wish list?
Thanks for any help/ideas
