Results 1 to 7 of 7
Thread: Can't see walls in AutoCAD 2012 from building designed in Arch. 2012
    2012-11
    28
    Default Can't see walls in AutoCAD 2012 from building designed in Arch. 2012
    So I've got a multi-level building that I designed in Arch. 2012. Now I'm using AutoCAD 2012 to draft out the building. The problem I'm having is that I can't see my wall sheeting or doors when I cut a plan view using 3DCLIP in a viewport. The building has been inserted into the drawing. Is there anything I can do to fix this or am I stuck drawing in some lines to represent the walls and doors?
    Cairo - no, not Illinois
    5,069
    Default Re: Can't see walls in AutoCAD 2012 from building designed in Arch. 2012
    Is the Object Enabler for Architecture loaded into your vanilla autoCAD?
    2012-11
    28
    No, and its doesn't appear that there is a O.E. for Arch. 2012 or AutoCAD 2012.
    5,069
    If there's not an OE available, then it's probably built-in to vanilla 2012.
    I suspect that the problem is that you are trying to do something in vanilla with an AEC object. that is - modify what's seen on screen. I think you'll need Arch to set up all views and sheets, and could only use vanilla for basic 2d drafting on those sheets.
    2012-11
    28
    Not modify, just want to see the doors and walls when I create a cutting section through the building when the bottom of the wall is cut out of the section in a multiple level situation. I tried to create the pages/viewports using Arch. but the same thing happens, as soon as you move the cutting plane above the base of the wall, the wall disappears.
    5,069
    You'll probably ned to ask this in the Architecure forum -- since it appears to be an Arch issue
    2004-12
    Athens Greece
    41
    Try PROXYGRAPHICS at command line and trun it on. Save your file and then try again.
  1. Replies: 0
    Last Post: 2013-06-12, 04:34 PM
  2. 2012: Space Naming Utility with more than one Arch Model
    By Dr._House in forum Revit MEP - General
    Last Post: 2012-08-03, 08:36 PM
  3. Autocad Map 3D 2010/Revit Arch. 2012 Problem
    By Ryan Cockerill in forum Revit Architecture - General
    Last Post: 2012-04-26, 01:24 PM
  4. 2012: Add items to Catalog - Autocad Arch 2012
    By Falcone in forum AutoCAD Customization
    Last Post: 2011-09-02, 05:24 PM
  5. 2012: Bay windows - Arch Cad 2012
    Last Post: 2011-07-24, 08:28 AM
