Thread: ACAD 2007 32-bit run on 64-bit
    2013-06
    Default ACAD 2007 32-bit run on 64-bit
    ACAD 2007
    How can I get 32-bit ACAD to run on 64-bit machine?
    2013-03
    Can you say DERECHO, Iowa
    66
    Default Re: ACAD 2007 32-bit run on 64-bit
    Quote Originally Posted by santafecanon386650 View Post
    ACAD 2007
    You should be able to without any additional work, Microsoft has an emulator called WOW64 that should automatically allow you to run a 32-bit program (regardless of the program).
    Have you tried running it and it won't run or it gives you an error message? I need more information if the above isn't working...
    9,805
    Are you asking because you want to try it, or because you have tried it and it doesn't work?
    Take a look at:
    http://forums.autodesk.com/t5/AutoCA...t/td-p/3680900
    http://www.eng-tips.com/viewthread.cfm?qid=283393
    http://answers.microsoft.com/en-us/w...3-993b3a1a878c
    2013-03
    66
    ACAD 2007
    Are you using Windows 7? What is your machine config?
  1. Mtext Issues Acad 2007 to Acad 2009
    By Eddy B in forum AutoCAD General
    Last Post: 2009-02-13, 12:37 PM
  2. Replies: 1
    Last Post: 2007-03-14, 04:39 PM
  3. Acad 2007 opening instead of C3D 2007
    By T-Towntech in forum AutoCAD Civil 3D - General
    Last Post: 2007-02-19, 05:57 PM
  4. Replies: 2
    Last Post: 2007-01-30, 10:51 AM
  5. ACAD 2007 saving down to ACAD 2004 - ARX Error: eDuplicateKey
    By Dicastaddict1 in forum AutoCAD General
    Last Post: 2006-10-26, 03:35 PM
