Thread: Can't find parameter to change it
    2009-04
    85
    Default Can't find parameter to change it
    Hi,
    Here is a question that might be simple for most contributors here, but I'm stuck.
    I have a structural model and a routine that inserts a Generic Family symbol (a little tag) at specific coordinates:
    dbDoc.Create.NewFamilyInstance(InsPoint, symbol, StructuralType.UnknownFraming);
    The Family has a Text type, Shared and Instance parameter (see attached image), whose value by default it’s an empty string.
    I would like to change the value of the parameter after the insertion, with the value (X, Y, Z) of the argument InsPoint used for the insertion, so that the tag becomes more visible.
    I’ve been able to find a lot a parameters (family, symbol, instance, type) but not this one!
    I'm convinced that it's something very simple, but I'm giving up!
    Can anybody help, please?
    TIA,
    Buddy
    2012-09
    34
    Default Re: Can't find parameter to change it
    Something like this:
    FamilyInstance familyInstance = dbDoc.Create.NewFamilyInstance(InsPoint, symbol, StructuralType.UnknownFraming);
    string coordinateString = InsPoint.X.ToString("F2") + ", " + InsPoint.Y.ToString("F2") + ", " + InsPoint.Z.ToString("F2");
    familyInstance.get_Parameter("XYZ").Set(coordinateString);
    I'm assuming InsPoint is an XYZ point, if it's not then adjust the code accordingly.
    double.ToString("F2") will cause the number to appear with 2 decimal places
    The above code will also need to take place during a Transaction.
    2009-04
    85
    Thanks cshha,
    That was really simple, I think I was way too tired because of all the trial-error efforts of yesterday and somehow, I couldn't see the forest for the trees
    Regards,
    Buddy
    2012-09
    34
    No problem. In future you should take a look at RevitLookup (part of the SDK) or BipChecker, which both let you examine all of the parameters of an element
    2009-04
    85
    I will, thanks.
    Buddy
  1. Find text, change layer
    By demetrius.adams707933 in forum AutoLISP
    Last Post: 2015-09-01, 11:24 PM
  2. mass change like find and replace
    Last Post: 2015-06-03, 12:51 PM
  3. 2015: Duplicated parameter in Find item drop down list
    By Bimerworld in forum NavisWorks - General
    Last Post: 2014-12-08, 04:13 PM
  4. Change Project Parameter to Shared Parameter?
    By kgodfrey in forum Revit Structure - General
    Last Post: 2008-11-12, 04:43 PM
  5. Can not find Change Space command in ADT 2007
    By klowery in forum ACA General
    Last Post: 2006-07-28, 12:44 AM
