Thread: Does anyone know what type of software they used for this video?
    2012-01
    59
    Default Does anyone know what type of software they used for this video?
    I'm relatively new to 3ds Max and I got into it because of the possibilities it creates for making videos for architectural purposes. How did they put this video together? more specifically how did they Integrate the 3-D model with existing footage? Was it a trick in 3ds max or something they did later in a video editing program?
    http://www.cgarchitect.com/2013/03/181-fremont
    2008-09
    Nebraska & Iowa
    378
    Default Re: Does anyone know what type of software they used for this video?
    Looks like 3dsMax w/ Vray if you ask me. No idea, that's just my guess. Maybe some added effects with premiere pro or after effects...?
    This might sound crazy, but it is quite possible that they had an entire well developed model of the city, complete with boats, trees, etc... and rendered like mad.
    2012-01
    59
    I did a little research after I posted this and I think they did it with 'camera tracking' in max or in another program
    2011-01
    Las Vegas
    31
    This friend is a lot of hard work, multiple software products, and the bar we all strive toward The basic rendering / modeling is likely done in either 3ds Max or Maya, with several plugins. There is a reason you only see videos like these on projects this size as well, because they are very expensive. I don't know if this is the case here but believe it or not companies hire people to digitally cut out areas to overaly their animated content. It's probably the position I come across more often then not. When you talk to an animator working a studio, they tend to have tons of time simply tracing pixels for years, frame by frame to accomplish this very task.
  1. showing last frame of video when video has ended
    By sobdeijn in forum DV - The 3rd Dimension
    Last Post: 2009-11-09, 07:15 PM
  2. ATI video card... has Revit video settings!
    By Wes Macaulay in forum Revit - Hardware & Operating Systems
    Last Post: 2009-02-16, 07:03 PM
  3. Video editing software recommendations
    By christo4robin in forum Revit - Rendering
    Last Post: 2005-02-03, 05:45 PM
