Results 1 to 10 of 10
Thread: Family using Lookup Table -
    2011-04
    18
    Default Family using Lookup Table -
    We are trying to create a lookup table to help size air terminals. We've got the table working, but defining Air Flow CFM is key. We are not able to find the correct param_name type definition for CFM.
    We can capture this: pxflow##Volume##Cubic_Feet but can't really convert that to CFM directly.
    What we need is pxflow##OTHER##Airflow ?? or cubic_feet_per_minute or some definition that will accept CFM value. pxflow##OTHER## returns "Inconsistent Units" when we pass CFM value to it.
    Does anyone know if this is possible or where this information could be found?
    Appreciate it; the forum is always helpful.
    2001-12
    Irvine, CA
    7,361
    Default Re: Family using Lookup Table -
    The format Revit expects is: Flow##HVAC_AIR_FLOW@@CUBIC_FEET_PER_MINUTE
    That said I suspect what you want to do runs counter to what Revit's workflow or expectations are. Revit expects that we provide a desired Air Flow at terminals (whether supply, return or exhaust) as a desired goal or criteria. The Duct Sizing feature is predicated on providing this at each terminal. It sounds like you are hoping to have this value supplied from a lookup table which sounds like a chicken and egg problem. Obviously I don't understand your approach or goal completely.
    2011-04
    18
    Thanks Steve! Yes, that is understood, we will have user supply the CFM when air terminal placed and from that the duct will size. I looked everywhere for this definition. Appreciate it. I'll let you know how it works out.
    ann
    2011-04
    18
    Worked like a charm. Is there a master list somewhere. Or is it just an obvious extrapolation? HVAC_COOLING_LOAD##BTU_PER_HOUR for example.
    This would open up a lot of possibilities.
    Very helpful, thank you, Steve.
    2001-12
    Irvine, CA
    7,361
    That is the general format syntax for MEP parameters. Just note the @@ versus ## though. I do remember reading a blog post in the past about formatting parameters in type catalogs but don't remember which one at the moment. I don't recall a master list though the wikihelp might have added some info. If I'm not sure I usually create a parameter and then use Export Family Types to a analog just to make sure I've got the format correct.
    2011-04
    18
    I'll make a note of the @@. Thanks again. As always, you are a great help.
    ann
    2001-12
    Irvine, CA
    7,361
    Sorry, managed to confuse myself! I typed @@ in my first example, but that is WRONG, it is a typo!! It should be ## in both instances, very sorry!
    Last edited by Steve_Stafford; 2013-06-27 at 01:19 AM. Reason: ironic, made a typo fixing a typo
    2010-04
    Perth, Australia
    117
    There is one book I have found that gives a list of "Valid Unit Types and Values For Each Dimensional Type", don't know how definitive or up to date it is given it was created for Revit 2010, and I know there are at least some parameter types added since then.
    Revit 2010: Family Standards and Best Practices by Shawn Zirbes & Integrated Content Solutions
    The latest version of Autodesk's families guide also has a list. That latest version is also 2010 however
    2001-12
    Irvine, CA
    7,361
    Fwiw, I decided to write a blog post on the subject tonight too.
    2011-04
    18
    No worries. Funny, though. @@ worked?? Changed it back. Good topic for blog post, I agree. It was really hard to track this info down. I was so close in my experiments, but never hit on the right type definition.
  1. 2013: Revit Mep family lookup table
    By MBU in forum Revit MEP - Families
    Last Post: 2013-12-17, 07:05 PM
  2. 2012: Lookup Table Question
    By Dr._House in forum Revit MEP - General
    Last Post: 2013-01-08, 06:01 PM
  3. Help! Lookup Table Possible?
    By mark.mcmullan in forum Revit MEP - Families
    Last Post: 2009-12-02, 05:27 PM
  4. lookup table units
    By alan.jackson in forum Revit MEP - General
    Last Post: 2009-10-06, 06:18 PM
  5. HELP! ! ! W/ Lookup Table
    By TerribleTim in forum Dynamic Blocks - Technical
    Last Post: 2008-09-10, 09:48 PM
