Thread: Pipe Accessory Family Inserts at Strange Angle
    2012-08
    6
    Default Pipe Accessory Family Inserts at Strange Angle
    I recently created a new Pipe Accessory family. I've done this many times before with no problems. But, this time when I insert the family into my model it always want to break into the piping at a strange angle instead of vertical. The family is defined as "always vertical" and was built in a vertical orientation. Any ideas on why this is happening? Sample screen shot is below. What I want is shown on the right, but what I'm always getting is shown on the left. I can rotate it to the correct angle, but this shouldn't be necessary.
    2015-11
    34
    Default Re: Pipe Accessory Family Inserts at Strange Angle
    Check the primary pipe connector for rotation in the family.
    2012-08
    6
    Yes, that was it. I never thought of that, but because of the hex shape it must have placed the pipe connector at a strange angle. Thanks.
    2006-12
    33
    The hex shape has that problem. but you could create a small round shape and add the connector at that round shape will solve this problem
  1. 2014: Pipe Accessory detail component not showing
    By cbulow556507 in forum Revit MEP - Families
    Last Post: 2014-02-26, 10:46 PM
  2. Pipe Accessory Annotation
    By phil.pleiss in forum Revit MEP - Families
    Last Post: 2013-03-08, 04:09 PM
  3. Show Symbols in Pipe & Duct Accessory families in Elevations and sections
    By Wish List System in forum Revit MEP - Families
    Last Post: 2012-06-30, 03:04 PM
  4. tag for pipe accessory
    By alan.jackson in forum Revit MEP - General
    Last Post: 2008-04-22, 05:00 PM
  5. Block Inserts a strange angle
    By kb3cxe in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-05-05, 05:31 PM
