Working in presenter to define material styles. Trying to use wrapped grid with orange color to represent construction/safety fence. The grid only shows up on horizontal planes. Vertical planes only have vertical lines. Same thing happens when I try to define a new material with an image file. When applied, it looks like the image file is tiled on the horizontal surfaces and extruded in the vertical. If I rotate on ST definition, it only rotates in the horizontal origin. Any ideas to get the image to show up on the vertical surfaces or both? Thanks.
