Results 1 to 6 of 6
Thread: Revit 2013 True North and Project North Toggle
    2013-07
    4
    Default Revit 2013 True North and Project North Toggle
    Hi. I've encountered a problem trying to get Revit 2013 to toggle between true north and project north. It appears that once I set true north in any plan view, project north is also set to the same orientation as true north and toggling between the two does not change anything. Any feedback would be much appreciated.
    2007-07
    94
    Default Re: Revit 2013 True North and Project North Toggle
    This means you haven't set up your true north. First change one view to True North, then you need to click on MANAGE>POSITION>Rotate True North. True north should follow the surveyor north arrow.
    2013-07
    4
    Quote Originally Posted by syew View Post
    After much experimentation, I rolled back all changes that I made (I should have mentioned that I have taken over an existing file) to see what happens if I simply switch between orientations in the properties before messing around with MANAGE>POSITION. When I first toggle to True North view, the orientation changes but subsequent to that, toggling between True and Project north does not change the orientation.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    ***A heads up that I moved this from BIM Management forum to the Revit Platform forum.***
    I would recommend starting with 2 separate views. One set to project north, the other set to true north. Tile these 2 views so you can see them both at the same time.
    Next, for both views, go into visibility graphics and expand the Site category. Turn on Project Base point and Survey point.
    Select Project base point first, ensure that it is clipped. Do the same for the survey point.
    Then in the view set to true north, try rotating your true north.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2013-07
    4
    Thanks Steve. Your suggested workflow helped us to isolate the problem: someone rotated the viewports to setup view orientations in lieu of adjusting the coordinate system.
    2015-12
    4,730
    Well. There you have it! Thanks for posting back the final piece of the puzzle.
  1. The Moving Linked CAD file (Project North True North)
    By mkim in forum Revit Architecture - General
    Last Post: 2019-06-03, 08:49 PM
  2. Losing colours between project north and true north
    By dominicsy in forum Revit Architecture - General
    Last Post: 2010-02-25, 05:08 PM
  3. True North Rotate and Project North Alignment
    By Firmso in forum Revit Architecture - General
    Last Post: 2007-06-13, 05:11 AM
  4. project north and true north arrow symbol
    By Justin Marchiel in forum Revit Architecture - Families
    Last Post: 2006-03-21, 07:49 PM
  5. Shadows in Revit 7.0 - True north, Project north
    By Tobie in forum Revit Architecture - General
    Last Post: 2004-12-14, 11:38 PM
Tags for this Thread
