Receiving the following Error when running clculations on bar joist in a larger model. Any help on what may be causing this error? Perhaps a meshing issue? ERROR1.JPG
In which version of Robot are such effects observed?
Similar issues for ANSI/AISC 360-05 code were fixed long time ago - in 2011 release.
Regards,
Pawel
Version 2014, yeah i should have mentioned its the first project we have worked on in RSA 2014 as well. Was an export from Revit 2014.
Such format of display of the ratio usually corresponds to some "out of range" values.
If the model was received from Revit then Revit and Robot files would be necessary to check it. Can you attach them? In case of Robot file compressing to ZIP can reduce the size significantly.
Pawel, my office does not want me to release our revit file. If i send you the robot file will that give you any insight into the problem?
Hi Pawel! Version numbers can be a separate field in thread titles here, you can see them at the top of the page, as shown in the attachment.
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
Hi Melanie,
thank you for this info - I have not noticed it
Regards,
Melanie Stone
@MistresDorkness
