I have looked for quite a while and can not seem to find an option to print the list of markups that I can easily see in the Markup Palette panel.
Is there such a way to print this list? or a work around that does not include print screen?
Yes... you can depending on the release you are using. I must say though... it is pretty useless depending on how you do your markups. It reports every line, arc, text, dimension etc. as separate entities.
Thanks for the reply,
I am using the 2013 version. I have not yet found a 2014 version.
I have not been able to decipher the method to get this report. I was kinda hoping for a report that would look like the markups palette panel with the markups per sheet. If it works like revit, I could create a schedule and extract the info.
What steps would you take to create this report. In the meantime I suppose I keep using multiple screen shots similar to this attachment.
Ken...
Here are the steps:
Perform a "Save As" and select "Save Markups Summary"
This will create a "CSV" file that you can then open with Excel or other reporting tool that supports CSV file imports.
Hope this helps you... as I said it is not a real clean report but you can use Excel etc. to clean it up.
Good luck...
Mike
Thanks Mike!!!! , that was the trick.
I should have known better after all these years with revit.... "Save as" not "print this"
