Hi all, please see attached image. I'm trying to dot in the foundation on an elevation. Any suggestions? Thanks.
You can use the Show Hidden Lines command on Graphics panel of the View tab. This is a view specific override.
From the wikihelp.
http://wikihelp.autodesk.com/Revit/e...9-Showing_1699
The lines aren't hidden though. I want to show the foundation with the "Hidden Lines" Line Style. Do I just need to draw over the foundation lines using detail lines? I just need to outline the foundation as shown in the attached pdf (red lines). Untitled-1.pdf
Ah! Misunderstood.
You can use the Linework tool on the View tab. Click on the tool, choose your linetype, select lines in the view.
