Thread: I thought these stairs would be easy in Revit.....
    2013-05
    23
    Default I thought these stairs would be easy in Revit.....
    or are they? - I just can't seem to figure out how to achieve them.
    Orlando, FL
    1,049
    Default Re: I thought these stairs would be easy in Revit.....
    Stair by component (Revit 2013 or '14). Do the sketch as shown, then do a landing, finish stairs. It does not work with the monolithic type, but with other such as "assembled stair 7 x 11".
    Another option is to do it as a generic model, but if you want it as a true stair, this is the way: green lines are boundaries, black lines are risers, blue line is the path. Then the landing is another sketch within the same tool.
    2001-12
    Irvine, CA
    7,368
    It's possible to use Monolithic if you use the Stepped option, really doesn't like the Smooth setting, stair disappears. See the finished and sketch images.
    2001-12
    Irvine, CA
    7,368
    I was doing something else with a Slab Edge and it occurred to me that a Slab Edge might actually provide a cleaner result and be nearly as fast as my previous example. So I tried it...not too shabby...
    Left Image = Final result from two angles
    Center Image = Section through slab/slab edge and Profile Family (Slab Edge)
    Right Image = "Worms eye" view of slab edge "steps" (view from below)
    The floor creates the top step so there are three sides to apply the slab edge to. I extended the profile under the slab so join geometry can clean up well. A wall of some sort (concrete) would be under the slab and behind the steps to finish it off.
    2013-05
    23
    Thank you so much Alfredo and Steve - so it seems there is a number of different ways to achieve this, very interesting, awesome. Thanks again. Sarah.
  1. Replies: 1
    Last Post: 2014-09-18, 04:40 PM
  2. Easy Keynoter – The next generation of Keynote editor for Revit 2015
    By phillip422256 in forum Revit - R & D Lounge
    Last Post: 2014-06-23, 06:19 AM
  3. Replies: 4
    Last Post: 2012-10-26, 05:17 PM
  4. An easy way to make Revit wall joins drive you insane
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2010-08-30, 10:24 AM
  5. Why I find Revit So Easy To Use
    By JTF in forum Revit Architecture - General
    Last Post: 2005-04-11, 03:43 PM
