Cut patterns aren't showing in details.
checked phase settings
checked VG settings
checked for overrides
What else could it be.
I'm being forced to to fill regions over the model. Doubling up on work.
checked VG settings
You can check your detail level down on the lower left corner of the screen. Make sure you have a hatch pattern specified for the detail level you need.
Rob
Set to fine.
Where do I set the cut pattern per view detail level?
The only place I know to set the cut patterns is in the wall type.
The Cut Pattern itself is set in the material but the display of it is controlled through the View. Bottom left, Level of Detail or through Visibility Graphics to change that for a specific category
