try this code right after insert a dynamic block as a start point,
this lisp was written in a hurry, so change to your needs
(defun c:cd (/
*error*
make-dynprop-dial
run-dynprop-dial
changedynblockprop
set_list
set_val
blk
dcl_ex
en
fn
fname
knock
lstpair
prop_lst
prop_name
val
val_lst
(vl-load-com)
(defun *error* (msg)
(if
(not
(member
msg
'("console break"
"Function cancelled"
"quit / exit abort"
) ;_ end of member
) ;_ end of not
(princ (strcat "\nError: " msg))
) ;_ end of if
(vla-endundomark adoc)
) ;_ end of defun
(setq adoc (vla-get-activedocument
(vlax-get-acad-object)
) ;_ end of vla-get-activedocument
) ;_ end of setq
(vla-startundomark adoc)
(defun make-dynprop-dial ()
(setq fname (strcat (getvar "dwgprefix") "dynprop.dcl"))
;;;(setq fname (vl-filename-mktemp "dynprop.dcl"))
(setq fn (open fname "w"))
(mapcar (function (lambda (x) (write-line x fn)))
(list
"dynprop : dialog {label = \"Change dynamic property\";"
": boxed_column {label = \"Select Parameter:\";"
"spacer;"
": popup_list"
"{label = \"Property name: \";"
"key = \"props\";"
"alignment = right;"
"value = \"0\";"
"multiple_select = false;"
"allow_accept = true;"
"edit_width = 24;"
"spacer;"
": popup_list"
"{label = \"Property value:\";"
"key = \"vals\";"
"value = \"0\";"
"edit_width = 24;"
"spacer;"
"spacer;"
"ok_cancel;"
) ;_ end of list
) ;_ end of mapcar
(close fn)
) ;_ end of defun
(defun run-dynprop-dial (blk / prop_name val)
(setq prop_lst nil)
(setq prop_lst (getproperties blk))
(setq dcl_ex (load_dialog fname))
(if (null (new_dialog "dynprop" dcl_ex))
(exit)
) ;_ end of if
(set_list "props" prop_lst)
(action_tile
"props"
(strcat
"(progn "
"(setq prop_name (nth (atoi $value) prop_lst))"
"(set_list \"vals\" (setq val_lst (getvalues blk prop_name))))"
) ;_ end of strcat
) ;_ end of action_tile
(action_tile
"vals"
"(setq val (nth (atoi $value) val_lst))"
(action_tile "accept" "(done_dialog 1)")
(action_tile "cancel" "(done_dialog 0)")
(setq knock (start_dialog))
(unload_dialog dcl_ex)
(vl-file-delete fname)
(list prop_name val)
) ;_ end of defun
(defun getproperties (blk / props)
(setq props (vlax-safearray->list
(variant-value
(vla-getdynamicblockproperties blk)
) ;_ end of variant-value
) ;_ end of vlax-safearray->list
) ;_ end of setq
(vla-get-propertyname x)
) ;_ end of lambda
) ;_ end of function
props
) ;_ end of mapcar
) ;_ end of defun
(defun getvalues (blk prop_name)
(mapcar 'vlax-variant-value
(variant-value
(vla-get-allowedvalues
(car
(vl-remove-if-not
(eq prop_name (vla-get-propertyname x))
) ;_ end of lambda
(variant-value
) ;_ end of vl-remove-if-not
) ;_ end of car
) ;_ end of vla-get-allowedvalues
) ;_ end of mapcar
) ;_ end of defun
(defun changedynblockprop (blk propname value)
(if (= (type blk) 'ename)
(setq blk (vlax-ename->vla-object blk))
) ;_ end of if
(setq dynobj_list
(variant-value
) ;_ end of setq
(foreach obj dynobj_list
(if (eq propname (vla-get-propertyname obj))
(vla-put-value obj value)
) ;_ end of if
) ;_ end of foreach
) ;_ end of defun
(defun set_list (name lst)
(start_list name)
(mapcar 'add_list lst)
(end_list)
) ;_ end of defun
(defun set_val (name val)
(set_tile name val)
) ;_ end of defun
;;(command "_-insert" "sw48")(while (= 1 (logand 1(getvar "cmdactive")))(command pause))
(setq en (entlast))
(setq blk (vlax-ename->vla-object en))
(make-dynprop-dial)
(setq lstpair (run-dynprop-dial blk))
(if (= knock 1)
(progn
(not
(vl-catch-all-error-p
(vl-catch-all-apply
'(lambda ()
(changedynblockprop blk (car lstpair) (cadr lstpair))
) ;_ end of lambda
) ;_ end of vl-catch-all-apply
) ;_ end of vl-catch-all-error-p
) ;_ end of not
) ;_ end of progn
) ;_ end of if
) ;_ end of defun
(prompt
"\n\t\t\t |-----------------------------|\n"
(prompt
"\n\t\t\t <| Start with CD to execute |>\n"
(prompt
(or (vl-load-com)(princ))
