Thread: Named Reference Planes, and regular reference planes - as different system families
    2008-05
    443
    Default Named Reference Planes, and regular reference planes - as different system families
    I use reference planes to align things throughout the model.
    I often end up creating so many, I get to a point where I just have to delete them all.
    This prevents me from using them as useful alignment objects. I recently needed to add two reference planes to alighn three roof vents on a 1/6 spacing. I would have liked to have changed these and left them, while still being able to delete the rest in the project.
    Or perhaps allow some features in the filter where we can sort for only reference planes named ________. And delete those. Give temporary reference planes a common name be default.
    It would also be pretty special to be able to set the extents of the refernece planes from the view created. Those roof reference planes I talked about above. I wouldn't want to see those in the plans below. I'd have to go hunt them down in a section or elevation and pull the bottoms up, as things are now.
    2015-02
    7
    Default Re: Named Reference Planes, and regular reference planes - as different system families
    I thing reference planes should have "types" like other families, and they appear in filters
  1. Families and Reference Planes
    By RPU_eric in forum Revit Structure - General
    Last Post: 2012-05-25, 10:48 PM
  2. Reference planes work planes and levels best practice
    By ree.espinoza in forum Revit - Platform
    Last Post: 2010-08-12, 03:09 PM
  3. Difference between Reference lines and Reference planes
    By adnama in forum Revit Architecture - General
    Last Post: 2009-10-28, 04:39 PM
  4. Managing Reference Planes in Complex Families
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2007-09-21, 05:56 PM
  5. "Unaming" Named Reference Planes
    Last Post: 2007-09-07, 05:23 PM
