Thread: Plotting with Overlayed Viewports
    2015-10
    Chicagoland
    73
    Question Plotting with Overlayed Viewports
    I hope this is the right location for this post. I am trying to essentially get a floor plan combined with a reflected ceiling plan on a single viewport & sheet. My current solution is to have a floor plan view with the floor plan elements that I want to see, and a reflected ceiling plan that shows just the ceiling grid, and possibly duct & mechanical equipment. This is working just fine. In Revit, I see objects the way I wish to see them.
    However, once I print, my output isn't what I see on the screen. It's almost like the reflected ceiling plan is "hiding" floor plan elements. The elements that I can't see are Conduit & Electrical Fixtures. But, I can still see the tags for those devices.
    I received this tip from someone else, so I know other people are doing it. What am I doing wrong?
    Thanks in advance,
    Shawn
    2015-10
    Chicagoland
    73
    Default Re: Plotting with Overlayed Viewports
    I figured out the solution. I had to set the RCP to Wireframe.
  1. 2015: Plotting pdf with irregular viewports
    By JeffLMoran355288 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2015-06-30, 05:03 PM
  2. Plotting viewports with Cad lite
    By tcone00 in forum CAD Management - General
    Last Post: 2009-06-03, 07:41 PM
  3. Clipped viewports not plotting
    By Senninha70 in forum AutoCAD General
    Last Post: 2008-09-24, 03:36 PM
  4. problem plotting with viewports
    By gisdude in forum AutoCAD Map 3D - General
    Last Post: 2006-07-25, 11:28 PM
  5. Viewports not plotting
    By patricia.ellistone in forum AutoCAD Plotting
    Last Post: 2005-07-28, 08:41 PM
