Thread: Help! How to make this one into a surface, and then I can divide it?
    2007-09
    83
    Default Help! How to make this one into a surface, and then I can divide it?
    I got a file like the attachment, sat format, and already import it into Revit, so ,that is the problem, how can I make a surface from this file?
    and more, that original object was set up in 3ds max
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Help! How to make this one into a surface, and then I can divide it?
    What type of surface are you trying to generate. If you try to apply anything to the face it won't work.
    2007-09
    83
    Quote Originally Posted by dhurtubise View Post
    I want to make a new surface from this one, and the new surface can be divided as others, with the U V parameters.
    2005-07
    3,792
    I would recreate the surface in Revit. Its fairly simple by creating a series of spline then pull & push points
    2009-03
    Somerville, MA
    1,060
    What program did the original surface come from? If you have access to the original surface and it is a NURBS surface (from Rhino or some such), then you can export it as an SAT and use it directly, subdivide it, etc, without recreating it in Revit.
  1. 2014: Custom divide surface pattern?
    By Spork in forum Revit Architecture - General
    Last Post: 2013-11-18, 09:18 PM
  2. make a surface into a 3d solid
    By jcushing in forum AutoCAD Civil 3D - General
    Last Post: 2011-05-09, 04:20 PM
  3. Best way to make a surface.
    By adam_J in forum AutoCAD Civil 3D - General
    Last Post: 2009-09-08, 05:40 PM
  4. "Divide Surface" in Revit 2010
    By ljohans in forum Revit Architecture - General
    Last Post: 2009-05-27, 12:40 AM
  5. How to make louver on a cylindrical surface?
    By Sonny Suyitno in forum Inventor - General
    Last Post: 2008-02-06, 05:04 AM
