Thread: DCL LISP routine to call different functions
    2013-07
    66
    Default DCL LISP routine to call different functions
    Hello everyone, I am attempting to have my lisp routine calling a dcl dialog box to execute a different function depending on which slide is selected by the user.
    Currently, there is only 1 trim length that the lisp is using, regardless of my attempts to have it do otherwise. I know my issue is within the (action_tile) and if I could find someone to assist in getting this correct for us I would be incredibly grateful. Thank you in advance, and now let's see the code.:
          (action_tile "Slide12"
           "(progn
               (setq Return$ Slide12$)(setq doAction 'T)
               (done_dialog)
    (action_tile
        "cancel"
          "(done_dialog) (setq doAction nil)")
       (start_dialog)
       (unload_dialog Dcl_Id%)
    (if doAction (SmallVLVInsert))
       (princ)
    );defun c:Smallvalves
    (done_dialog)
    (defun SmallVLVInsert ( / ss p2 p3)
    (done_dialog)
    (command "attreq" "0")
    (if (eq 16384 (logand 16384 (getvar "osmode")))
    (setvar "OSMODE" (boole 6 (getvar "OSMODE") 16384)))
    (command "snap" "0.0625")
    (setq insertpt1 (getpoint "\nPick Insertion Point on line: "))
    (if (not (tblsearch "layer" "pid"))
      (entmake
        (list
          (cons 0 "Layer")
          (cons 100 "AcDbSymbolTableRecord")
          (cons 100 "AcDbLayerTableRecord")
          (cons 2 "pid")
          (cons 70 0)
          (cons 62 3)
          (cons 6 "Continuous")
    (setq Snap (getvar "osmode"))
    (setvar "clayer" "pid")
    (command "_insert" Return$ insertpt1 "" "" "")
    (while (not ss)
      (setq ss (entsel "\nSelect line to break: "))
      );while
      ;(while (not p3)
       (setvar 'osmode 613)
       (setq p3 (getpoint "\nPick valve center:")
             p2 (angle p3 (cadr ss))
    (command "break" ss "f" (polar p3 p2 0.093750)
                            (polar p3 p2 -0.093750))
      (setvar "cmdecho" 1)
      (princ)
      (setvar "osmode" Snap)
    );if
    Only a small excerpt but I believe it illustrates my problem well enough.
    If I were to want to add a 2nd function below the last closing bracket ");if",
    then it seems as if the routine only sees the first function and will trim the line around the selected block the distances specified in the first defun SmallVlvInsert. I would like to add a FlanSmlValveInsert that trims to .1172 instead of the 0.093750 that is in the SmallVlvInsert, but trims in the same way because it works fine and good. Of course any upgrades or error checking would be gratefully accepted and placed into this code.
    Thank you
    2013-07
    66
    Default Re: DCL LISP routine to call different functions
    Hi again, I will attach the corresponding lisp and dcl files so that anyone may take a look at the code in full.
    Thanks again.
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Here is an example of using slides and image tiles.
    Take a look...
    It isn't that complicated.
    Ask if you have trouble.
    P=
    AutomateCAD
  1. Replies: 9
    Last Post: 2012-01-21, 07:58 AM
  2. Call MDDEDIT from a Lisp Routine
    By JeffClark in forum AutoCAD Customization
    Last Post: 2010-08-25, 08:47 PM
  3. Does this call for a lisp routine?
    By behrooz.mirfathali in forum AutoLISP
    Last Post: 2008-11-04, 03:10 PM
  4. Replies: 4
    Last Post: 2005-12-06, 04:17 PM
  5. How is your computer set up to call a LISP routine?
    By jack.frahm in forum AutoLISP
    Last Post: 2005-02-18, 01:52 PM
