Thread: Display Order / Draw Order
    2008-12
    New Jersey
    472
    Question Display Order / Draw Order
    Has anyone else noticed this: Using the Tools pull down menu and/or the Ribbon it is called Draw Order yet if you use the right click short cut menu, it calls it Display Order. I found this a bit funny for some reason.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Display Order / Draw Order
    While DRAWORDER is the command it changes Display Order not the Drawn Order. I think Display Order is a better description of what it does.
  1. Display/draw order for Architectural text
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-06-12, 10:30 PM
  2. Draw Order
    By wags5116 in forum Revit MEP - General
    Last Post: 2011-05-05, 10:55 AM
  3. 2011: Draw Order No Help
    By wbush in forum AMEP General
    Last Post: 2011-03-08, 01:29 PM
  4. Draw order
    By scontreras in forum AutoCAD Map 3D - General
    Last Post: 2009-08-05, 07:46 PM
  5. Draw Order
    By tsigler in forum AutoCAD General
    Last Post: 2007-10-26, 06:56 PM
