Hi All
I've got a point cloud file sitting in Revit 2013. All I want is some program or to build a surface or mesh.... just something to join the dots so when I cut a section I will be able to see, for example two lines where the wall is cut, or two lines for the thickness of the slab.
It must be a one-click solution. Not for accuracy but just to examine the points as faces, surfaces, meshes. And hopefully when it creates a surface, I can cast shadows as well.
Is there such a program? Tried cloudcompare, meshlab, PCL (couldn't get that to work - prob me), 3ds max (w/ cloudstomax plugin), Inventor, Autocad, rhino, ScantoBIM, sketchup.
Thanks
Eugene
