Thread: revit 2014 to navisworks 2014
    2009-07
    Swartz Creek, MI
    21
    Unhappy revit 2014 to navisworks 2014
    hi all. just to give you a quick background. i just got a new laptop, and upgraded to the ultimate design package. i have been through all the tutorials that i can find. i have a couple issues. 1st with this installation, for some reason the add-in for exporting to navisworks is not loaded in revit like it was in my old versions. 2nd i tried opening the building that i completed in Revit with Navisworks. for some reason the only part of the Revit file that appears in the Navisworks view are the grids. and the Structural model that was done with Autocad will also show up in Navis. i'm completely lost on this topic. any help would be greatly appreciated.
    2007-09
    490
    Default Re: revit 2014 to navisworks 2014
    Having a similar situation here. Installed the BDS Ultimate, which includes Revit and NW Manage 2014. First, the NW exporters do not appear in Revit like they have in the past - assuming it is because NW can open the .rvt format. Second, the installer for the NW exporters from Autodesk refuses to install on my machine. It begins the unpacking process and then hangs at about 20%
    Probably going to file a support ticket on this but I thought I would see if anyone else is running into similar problems. Getting the SPs and extensions installed in the right order for 2013 was like rocket science.
    2009-07
    Swartz Creek, MI
    21
    hi Ninja, try this link: http://www.autodesk.com/products/aut...export-utility
    the .exe file on that page worked for mine.
  1. 2014: Revit 2014 to NWC to Naviworks manage 2014
    By Bimerworld in forum NavisWorks - General
    Last Post: 2014-11-13, 04:12 AM
  2. Replies: 5
    Last Post: 2014-05-05, 02:33 PM
  3. 2014: Navisworks Exporter 2014
    By jcurtis367595 in forum Revit MEP - General
    Last Post: 2014-02-06, 05:13 PM
  4. 2014: Navisworks 2014 on Windows 8
    By calladj in forum NavisWorks - General
    Last Post: 2013-09-03, 11:15 AM
  5. Replies: 2
    Last Post: 2013-04-30, 12:44 PM
Tags for this Thread
