the first is on the second point and the second is on the first pointCode:Public Sub ImportarAtributos() Dim aListaPuntos() As Double Dim aListaTextos() As String Dim insertionPoint(0 To 2) As Double Dim sIdentificador As String Dim sSolicitud As String Dim sValor As String Dim attributeObj As AcadAttribute Dim blockObj As AcadBlock Dim blockRefObj As AcadBlockReference Dim iBloquesExistentes As Integer Dim varAttributes As Variant ReDim aListaPuntos(5) aListaPuntos(0) = 10: aListaPuntos(1) = 10: aListaPuntos(2) = 10 aListaPuntos(3) = 20: aListaPuntos(4) = 20: aListaPuntos(5) = 20 ReDim aListaTextos(1) aListaTextos(0) = "First on point 10,10,10" aListaTextos(1) = "Second on point 20,20,20" iBloquesExistentes = ThisDrawing.Blocks.Count insertionPoint(0) = 0 insertionPoint(1) = 0 insertionPoint(2) = 0 Set blockObj = ThisDrawing.Blocks.Add(insertionPoint, "ISBlock" & iBloquesExistentes + 1) Set PointObj = blockObj.AddPoint(insertionPoint) sSolicitud = "prompt" sValor = aListaTextos(0) sIdentificador = "tag" Set attributeObj = blockObj.AddAttribute(1, acAttributeModeVerify, sSolicitud, insertionPoint, sIdentificador, sValor) insertionPoint(0) = aListaPuntos(0) insertionPoint(1) = aListaPuntos(1) insertionPoint(2) = aListaPuntos(2) Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPoint, "ISBlock" & iBloquesExistentes + 1, 1#, 1#, 1#, 0) varAttributes = blockRefObj.GetAttributes varAttributes(0).TextString = aListaTextos(1) 'tomamos el punto de insercion del bloque insertionPoint(0) = aListaPuntos(3) insertionPoint(1) = aListaPuntos(4) insertionPoint(2) = aListaPuntos(5) Set PointObj = ThisDrawing.ModelSpace.AddPoint(insertionPoint) Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPoint, "ISBlock" & iBloquesExistentes + 1, 1#, 1#, 1#, 0) End Sub
how can i fix this?
thanks
