Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Adding Custom Fields to Rename & Renumber Sheet Set Dialog Box
  1. #11
    Default Re: Adding Custom Fields to Rename & Renumber Sheet Set Dialog Box
    I can verify that BlackBox is correct. There is no way to add Custom Fields to the Rename & Renumber Sheet Set Dialog Box but with SSMPropEditor the renaming tasks can be done very easily and if there still are functions you miss in SSMPropEditor they can most probably be added.
  2. #12
    5,719
    Quote Originally Posted by jimmy.bergmark View Post
    Thanks for the confirmation, Jimmy... It's always nice to see you here. *tips hat*
    Cheers
  1. Renumber/Rename/reorder Grids
    By priitl22047477 in forum Revit Structure - General
    Last Post: 2010-01-17, 07:49 PM
  2. Combine Sheet Properties and Rename and Renumber Windows
    Last Post: 2008-06-02, 03:35 PM
  3. New Rename & Renumber Feature Greyed Out
    By andrew_carpenter in forum ACA General
    Last Post: 2005-08-01, 04:30 PM
  4. FIELDS ( current sheet custom )
    By pangell in forum AutoCAD Fields
    Last Post: 2005-06-07, 04:54 PM
  5. new sheet set with existing drawings custom fields
    By jkipfer in forum AutoCAD Sheet Set Manager
    Last Post: 2005-02-22, 04:57 PM
