Thread: Text within line (symbol line), opaque background not printing
    2012-08
    14
    Default Text within line (symbol line), opaque background not printing
    We have a family made in order to have letters/symbols as a linetype, seeing as revit won't let you do this.
    We have the text background set to opaque, and have sent the line to the back, so that part of the line is shown as a break with the text easily readable. The issue is, it displays correctly on screen but does not print like this (hard copy or pdf).
    Can anyone tell me what is wrong and why this won't work?
    I have attached screen shots of the line ON screen (displays correct) and a screen shot of a PDF (displays incorrectly - you can't read the text). I have also included the symbol line family. (please note - I did not make the family, but a previous colleague in the office made it/sourced it)
    2015-11
    5
    Default Re: Text within line (symbol line), opaque background not printing
    Hi,
    I've run into the same situation with a label that is nested into a family. Were you able to find a solution.
    Thanks
    2012-08
    14
    Quote Originally Posted by pial01 View Post
    Hi,
    Thanks
    Sorry, no luck yet! seems no one else has any idea's either by the lack of response! Very annoying - we use this type of line on the majority of our stuff and it looks tacky and is very hard to read with the line covering the text
    2010-10
    Chicago, IL
    376
    There could be a better solution and probably is, but until someone else comes up with a better one, here it is.
    In the text family (Generic Annotations), I've added a masking region with a width and a height parameters (Blank Spot Height and Width), so depending on the text size, you can control the size of the voids in the line.
    2012-08
    14
    PijiPiwo - thank you, this seems to be working, hallelujah! haha.
    Meanwhile, it seems as though revit's "what you see is what you get" method isn't so true afterall. perhaps we can dare to dream with new releases being able to make linetypes that will accept Letters & symbols and do away with all these work-arounds.
  1. Text Frames and Background Masks Don't Line Up
    By tstgelais849562 in forum AutoCAD Civil 3D - General
    Last Post: 2012-11-06, 10:15 AM
  2. I wish I could create custom line patterns with symbol/letters in the line pattern.
    Last Post: 2010-11-13, 12:43 AM
  3. Add a center line symbol to a block to text
    By avillamor.124544 in forum AutoCAD General
    Last Post: 2007-05-30, 06:24 PM
  4. opaque text shows up black when printing dwf
    By khanson-3b in forum Revit - Plotting/Printing/Exporting
    Last Post: 2006-09-06, 10:52 PM
Tags for this Thread
