Thread: Feature labels
    2004-06
    Slidell, Louisiana
    972
    Default Feature labels
    I have a project that has several shp files in it. one of them has 2 fields i need to include in the label.
    I've managed to figure out how to display both fields. i'm using plain text and the expression is Concat(Watertype, '\n', WaterWidth)
    It displays the text on 2 lines, but it appears to be center justified. how do i get it to be either left or right justified.
    Also, is there a way to include a foot mark (') after the width or just ft.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Feature labels
    Not sure on the justification, but you might try adding '/'' for the foot mark in the location you need.
    If you click the Advanced section of the Style Label dialog box, you can adjust the alignment
    If you use points, you can pick anywhere around the point to label.
    For lines, you can use a Fixed Location and tweak the Horizonal Alignment.
  1. History feature or time tracking feature
    Last Post: 2013-11-19, 07:56 PM
  2. 2012 Feature Labels will not print
    By jodneal361267 in forum AutoCAD Map 3D - Annotations
    Last Post: 2012-12-05, 08:25 PM
  3. Replies: 0
    Last Post: 2010-09-21, 02:11 PM
  4. Feature Labels Drawing Order
    By bcowper in forum AutoCAD Map 3D - General
    Last Post: 2008-04-30, 04:58 PM
