Results 1 to 7 of 7
Thread: Line Types - Hot water lines vs cold water lines vs gas lines
    2012-04
    Pottsville, PA
    167
    Default Line Types - Hot water lines vs cold water lines vs gas lines
    Hi! Is it possible to create a custom line with letters for example to create a hot water/ cold water/ gas lines (ex. ----- H ------ = Hot water ----- C ---- = Cold Water ----- G ---- = Gas line)?
    Thanks!
    Rob
    2003-12
    40
    Default Re: Line Types - Hot water lines vs cold water lines vs gas lines
    Line Type .... No
    You can do a line based family though that has symbols and text. See example.
    2001-12
    Irvine, CA
    7,567
    You can tag pipes with parameters that make them "look" like just lines with letters. These tags are showing the parameter value assigned to System Abbreviation for each Pipe System.
    2012-04
    Pottsville, PA
    167
    Thanks Gary and Steve! I will give it a try.
    Take care,
    Rob
    2014-02
    6
    Thats awesome! Question thou Steve or anyone else did you have to place each of those tags? Or can you somehow tell revit to place a tag at equal intervals?
    Thanks!
    2014-02
    6
    Can you make the tags be applied to the pipe automatically over equal intervals somehow? Ie multiple tags on each section of pipe say 2000mm apart?
    2001-12
    Irvine, CA
    7,567
    No not really, not without the API (programming a routine to do it). Tag All will let you tag a lot of pipe at one time, but once, and that hasn't already been tagged.
  1. 2013: Hot and Cold Water Pipe Connectors
    By bhollon in forum Revit MEP - General
    Last Post: 2014-04-14, 05:26 PM
  2. 2014: How do you separate plan views for Hot & Cold Water?
    By rstavares in forum Revit MEP - General
    Last Post: 2013-10-31, 05:12 PM
  3. Cold and hot Water pipe sizing for Spain
    By bejenaru.a in forum Revit MEP - Wish List
    Last Post: 2011-11-21, 09:46 PM
  4. Water lines not accepting system type change
    By russell.eckstein in forum Revit MEP - General
    Last Post: 2011-11-21, 06:28 PM
  5. Defpoint Lines / Construction Lines / No Plot lines
    By ykang in forum Revit Architecture - General
    Last Post: 2006-11-14, 10:30 PM
Tags for this Thread
