Hi Friends.
can any body tell me how can i edit the style of Ordinate dimension.
i need ordinate dimension same like Leader, which have arrow.
is it possible in autocad......!
Hi Friends.
I do not know of an ordinate style as you describe however you can use a regular type dimension and with system variables suppress the display of one or the other extension lines (DIMSE1, DIMSE2) as well as either dimension line and arrow (DIMSD1, DIMSD2)
after looking thru the variables, I could not find anyway to change how the ordinate dimension can have and arrow on the end of the line it generates. Two options are 1) draw over the ordinate lines with a leader. 2) make an arrow block and insert it on the end point of the ordinate line
