Hello dear BIM colleagues. I have a project that is quite complex, and I want to create a parametric conceptual mass to drive the overall profile changes due to owner/design requests. The project is a tower, that is designed in multiple curvilinear profiles. At the levels where the profiles change, they do so in an undulating effect.
The issue is that this project is going through many iterations, and the profiles keep on changing. I am trying to create a parametric conceptual mass, at the very least to modify the profiles through numerical values, as opposed to keep on redrawing the profiles from scratch, over and over, you get the point...The profiles are arcs, that join tangentially (this is where it get difficult). Unfortunately, revit doesn't love arcs, especially multiple arcs working together. I have been hitting a wall, trying to achieve revit to do parametric tangential arcs !!!
The project is created using Revit 2013.
I am an acting BIM/Revit user, experienced, but have not dealt much with creating masses from parametric tangential arcs...I am open to ideas,
( I have posted this also on revitforum.org, but received no answer, therefore I am trying my luck here...)
Thank you,
TowerDesign_Geometry.pdf
Rafael
