We all know that we can input attribute in a block using attdef command. But Is there any facility to input attribute in simple acad object like line circle etc without making a block? If so how ? I am using Acad 2002 now.
Hi
Simple answer no.
Have a good one, Mike
Thanx Mike. But please suggest the algorithm what is the way to do it in a simple way.
Hi
By definition Attributes have to be part of a Block, therefore if you want to use Attributes you will have to create a Block.
If you want to store data with AutoCAD Objects then you could look at things like Drawing Dictionaries / LData / XData.
A Forum Search will turn up relevant information on the above.
