Thread: Revit Keynote Legends not behaving correctly on different sheets
    2015-10
    17
    Default Revit Keynote Legends not behaving correctly on different sheets
    Not entirely positive this is related, but upon upgrading to 2014 from 2013, our Keynote Legends which had been behaving perfectly across numerous sheets, now appear to be inconsistent. The most annoying item is that we typically, under the Keynote Legend Properties, edit schedule, Appearance tab, select "Blank row before data". This allows the header to fit in a nice little titleblock area we have established on our sheets. Unfortunately, there's about a 90% chance now that the legend, once on the sheet, will not honor that and just eliminates the blank row.
    We've deleted the legend from the sheets, drug new ones onto the sheet, copied "working" legends form other sheets onto those sheets... but to no effect.
    Any ideas?
    Augi Keynote Exhibit.pdf
    100 Club Overconstrained's Avatar
    2005-05
    Hamilton NZL
    158
    Default Re: Revit Keynote Legends not behaving correctly on different sheets
    I've had a similar issue, the only way I've found to fix it is to remove then reapply a schedule view template to the schedule.
    Senior Architectural Technician
    Dean Burdett
    SEKTA Architects Ltd.
  1. Different Keynote Legends on different sheets?
    By Dave Jones in forum Revit Architecture - General
    Last Post: 2018-05-29, 07:59 PM
  2. Legends on Multiple Sheets
    Last Post: 2014-11-13, 10:19 PM
  3. Keynote legends: how can I keep them under control?
    By rjcoolpix880 in forum Revit Architecture - General
    Last Post: 2009-12-09, 05:59 PM
  4. Daylight not behaving correctly
    By KansasCAD in forum AutoCAD Civil 3D - Corridors
    Last Post: 2008-10-20, 04:41 PM
  5. Rotation of Schedules and Legends on sheets
    By Revit Wishes in forum Revit Architecture - Wish List
    Last Post: 2007-09-21, 02:46 AM
