Thread: Instance Arc Grip/Handle Issue
    2012-11
    Default Instance Arc Grip/Handle Issue
    I made a family that will arc and move with grips. It works exactly how I want it..... except....I am having a problem when the arc is getting too small. The model geometry will then flip to the opposite side, but annotation will look fine. I locked the sweep path to the annotation with the formula for the radius. Is there a way to make a if statement to flip it? I would be happy with a yes/no to flip it. I am thinking it has something to do with the behavio of the sweep?. I will attach a few pictures with the issue.
    2006-12
    33
    Default Re: Instance Arc Grip/Handle Issue
    It is better to create a horizontal reference line to control the center point of the Arc. if constrains applied correctly, it won't be flipped.
    If you want it to be flipped that, you could create two sweep at the same time, and use visibility to control the two sweeps.
  1. 2015: What determines instance parameter grip "snap" and "align" behavior?
    Last Post: 2015-08-27, 10:45 PM
  2. Instance Length Instance Parameter: Reporting Issue
    By pashley in forum Revit Architecture - Families
    Last Post: 2012-06-27, 08:10 AM
  3. Grip location for instance parameters
    By Dimitri Harvalias in forum Revit Architecture - Families
    Last Post: 2012-02-08, 06:42 PM
  4. Grip issue with Dynamic block
    By tracyhennigan in forum Dynamic Blocks - Technical
    Last Post: 2010-03-15, 04:21 PM
  5. Blue grip arrows (instance parameters) won't snap to objects
    By patricks in forum Revit Architecture - Families
    Last Post: 2009-02-12, 03:36 PM
