Thread: Displaced Element
    Default Displaced Element
    I'm wanting to use the displaced element function in Revit 2014 with some elements that I have created an assembly out of. It appears that the displaced element will not work when the elements are assembled. I created tilt-up panel shop drawings from the elements grouped as an assembly. Now I want to do a displaced view of the elements to better show the complexity of the connections but it appears that I can't when the elements are assembled.
    Any thoughts on how to do this without exploding the assembly. When I do explode the assembly I can use the displaced element function just not when they are assembled.
    Default Re: Displaced Element
    Can you try and tab-select the element inside of the Assembly and then click the Displace Elements button?
  1. 2013: Elements in Curtain Panel families getting displaced
    By mattolsen.nz449001 in forum Revit Architecture - Families
    Last Post: 2014-01-14, 02:43 PM
  2. Replies: 1
    Last Post: 2010-07-15, 08:43 PM
  3. Created family - Parts displaced?
    By kappy in forum Revit Architecture - General
    Last Post: 2010-06-03, 02:27 PM
  4. Layout displaced?
    By mtc.139414 in forum AutoCAD LT - General
    Last Post: 2007-06-28, 02:43 PM
  5. Displaced pattern when pasting
    By susanima in forum AutoCAD LT - General
    Last Post: 2005-08-17, 11:05 AM
